Pokeys_homecomp EncoderSearch / Encoder Arm Topic: Pos_Fb Following errors
6 years 2 months ago #178890 by JR1050
A couple years ago I intalled this Pokeys patch and it all worked. When attemping to do it tonite, I got the following
zoey@zoey:~$ sudo apt-get install libusb-1.0-0-dev
[sudo] password for zoey:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package libusb-1.0-0-dev
E: Couldn't find any package by regex 'libusb-1.0-0-dev'
zoey@zoey:~$
I changed the stanzas in the apt file to reflect the archives, like so
deb http.archive.debian.org/debian/ wheezy main contrib non-free
deb-src archive.debian.org/debian/ wheezy main contrib non-free
deb http.archive.debian.org/debian/ wheezy-updates main contrib non-free
deb-src archive.debian.org/debian/ wheezy-updates main contrib non-free
Is there anyway to install the libusb dev file? It appears to be unavilable. It seems available as a tarball, how would one install it and does it have to be ver 1.0-0-dev or can it be a later version? At this point with Wheezy being depreciated, what is the next best option? Thanks
5 years 6 months ago #207397 by MATZE-ATZE-SCH
Replied by MATZE-ATZE-SCH on topic Pokeys
Hello,
I have LinuxCNC 2.8.0 on Debian 10 and try to install the Pokey57U.
I have followed the steps from Andy on page 10.
In the Halshow I see the Pins, but the pokey.0.alive isn´t blinking and the IN0 isn´t respnse to a switch I connected to the Pokey for testing.
Is this a error because LinuxCNC 2.8, or Debian 10?
In the Terminal with "lsusb" I see the connected Pokey.
Also the compile of pokey.comp seems correct...
Maybe an error with RW permission for the Pokey caused by Debian10?
Best regards
Marcel
5 years 6 months ago - 5 years 6 months ago #207473 by MATZE-ATZE-SCH
Ok,
have tried the steps again,
now I get an error message when try to compile the pokeys.comp with "sudo halcompile --install pokeys.comp":
gcc -I/usr/include -I/usr/include/linuxcnc -URTAPI -U__MODULE__ -DULAPI -Os -o pokeys /tmp/tmpSkpKFD/pokeys.c -Wl,-rpath,/lib -L/lib -llinuxcnchal
/usr/bin/ld: /tmp/ccUQNzda.o: in function `writeI2C':
pokeys.c:(.text+0x436): undefined reference to `PK_I2CWriteStart'
/usr/bin/ld: pokeys.c:(.text+0x44d): undefined reference to `PK_I2CWriteStatusGet'
/usr/bin/ld: /tmp/ccUQNzda.o: in function `readI2C':
pokeys.c:(.text+0x49b): undefined reference to `PK_I2CWriteStart'
/usr/bin/ld: pokeys.c:(.text+0x4ab): undefined reference to `PK_I2CReadStart'
/usr/bin/ld: pokeys.c:(.text+0x4ce): undefined reference to `PK_I2CReadStatusGet'
/usr/bin/ld: /tmp/ccUQNzda.o: in function `main':
pokeys.c:(.text.startup+0x89): undefined reference to `PK_ConnectToDeviceWSerial'
/usr/bin/ld: pokeys.c:(.text.startup+0xa1): undefined reference to `PK_DigitalIOGet'
/usr/bin/ld: pokeys.c:(.text.startup+0xb5): undefined reference to `PK_AnalogIOGet'
/usr/bin/ld: pokeys.c:(.text.startup+0x275): undefined reference to `PK_DisconnectDevice'
collect2: error: ld returned 1 exit status
make: *** [Makefile:2: pokeys] Fehler 1
Any sugestions?
EDIT: Sorry, my fault, have used the wrong .comp...
But still unable to get it to work
Last edit: 5 years 6 months ago by MATZE-ATZE-SCH.
5 years 6 months ago #207482 by MATZE-ATZE-SCH
Hello,
I have now try a few thinks:
On a different HDD I have installed Debian 9 with Linuxcnc 2.7,
there it works.
Then I have upgrad LinuxCNC to 2.8,
there it worked also, the alive pin is blinking and the switch on in 1 is toggeling.
So I think it is no issue of Linuxcnc or the version of it,
I think it is an issue with the Debian 10?
Best regards
Marcel
5 years 6 months ago #207506 by MATZE-ATZE-SCH
OK, finally I have got it to work!
I have set in the
90-usb-pokeys.rules
the Mode to 666
SUBSYSTEM=="usb", ATTRS{idVendor}=="1dc3", ATTRS{idProduct}=="1001", GROUP="plugdev", MODE="666"
Then, while LinuxCNC is running, I have unpluged and replugged the Pokey, and then it works, even when I replug it or restart the PC...
The following user(s) said Thank You: andypugh, robins, LAUSCH
4 years 9 months ago - 4 years 9 months ago #231707 by mechoil
Replied by mechoil on topic Pokeys ethernet
Finally was able to make it work through ethernet (not tested with real hardware!)
Need to change line in pokeys.comp:
while(dev == NULL)dev = PK_ConnectToDeviceWSerial(12345, 5000);  //waits for usb device to while(dev == NULL)dev = PK_ConnectToDeviceWSerial_UDP(12345, 5000);  //waits for usb device
In my case network discovery didn't work, so i've changed this file:
diff --git a/PoKeysLibCoreSockets.c b/PoKeysLibCoreSockets.c index 61f68fd..f6561eb 100644 --- a/PoKeysLibCoreSockets.c +++ b/PoKeysLibCoreSockets.c @@ -287,7 +287,7 @@ int32_t PK_SearchNetworkDevices(sPoKeysNetworkDeviceSummary * devices, uint32_t          // Send discovery request...          remoteEP.sin_family = AF_INET;          remoteEP.sin_port = htons(20055); -        remoteEP.sin_addr.s_addr = a; // inet_addr("255.255.255.255"); +        remoteEP.sin_addr.s_addr = inet_addr("255.255.255.255");            if (sendto(txSocket, SendBuf, BufLen, 0, (SOCKADDR *)&remoteEP, sizeof(remoteEP)) == -1)          {
Last edit: 4 years 9 months ago by mechoil. Reason: fix format
The following user(s) said Thank You: LAUSCH
Time to create page: 0.521 seconds
