Pokeys_homecomp EncoderSearch / Encoder Arm Topic: Pos_Fb Following errors
4 years 2 months ago #249456 by MATZE-ATZE-SCH
Replied by MATZE-ATZE-SCH on topic Pokeys - Encoders
Hello Dominik,
have try it out, but without sucess...
Compiling without errors,
the pins are visible in halshow.
but the .alive isn´t blinking.
Also the .err is not on.
in the .deb is a 0.
Best regards
Marcel
4 years 2 months ago #249464 by zarfld
Replied by zarfld on topic Pokeys - Encoders
so it seems that there is an problem to connect
thats the sequence of code:
        deb=0;         while(dev == NULL)dev = PK_ConnectToDeviceWSerial(devSerial, 2000);  //waits for usb device                   alive=1;          deb=1;         err=0;
theres not much between setting deb 0 an 1. And as this section is still similar to the one found at page 10, we should get it to work with some simple checks.
- the command used expects the pokeys connected via USB
- the other thing is to check the value of "devSerial" (which is kind of the address to ensure that the right device is connected)- this should match the serialnumber of your pokeys device (you may set it in HALConfiguration and/or HAL-File using "setp pokeys.0.devSerial [pokeys serial]")
- it hink you already checked if it's powered on
- besides that you might doublecheck instructions in forum.linuxcnc.org/24-hal-components/298...rnet?start=90#162953
BR
Dominik
4 years 2 months ago #249467 by MATZE-ATZE-SCH
Hey Dominik,
-Pokey is connected via USB, yes
-dev-Serial is correct, set in hal with setp pokeys.0.devSerial 12345
-power is on, the red and green light are on on pokeys.
-done all the steps again...
If I compile the pokeys.comp from page 10, everything runs as it should, beside of the potis.
the alive is blinking, the err pin is off.
Then I close Linuxcnc and compile your pokeys.comp.
no error, see the pins in Linuxcnc, but no alive and deb = 0
If then I close Linuxcnc, compile the pokeys.comp from page 10, and start linuxcnc, everythink works just fine...
I don´t know what to do... :/
4 years 2 months ago - 4 years 2 months ago #249471 by zarfld
yes trying the original file of page10 is a good idea - to ensure that the system is basically working.
anyway i managed to access my system remotely and tried to reproduce the problem - on my raspberry having a dummy config it seems to work - but as the deb=13 it seems that it is periodically disconnecting
i can hradly see the alive-flag flashing on "HAL Konfiguration" page - i assume because of display latency due to remote connectionbut in HAL-Osziliskope you can see the values changing.
So i reverted that part of DigitalIO and AnalogIO to be similar as on page10 compiled and - this time - tested if the code runs
(anyway still no encoders connected as i'm not there)
File Name: pokeys_202...0-2.comp
File Size:1.75 KB
hope that's similar on your system
Last edit: 4 years 2 months ago by zarfld.
The following user(s) said Thank You: MATZE-ATZE-SCH
4 years 2 months ago #249472 by MATZE-ATZE-SCH
It seems to work!!! image missing /media/kunena/emoticons/laughing.png
The . alive is blinking,
.in-1 works also, the .deb is counting up and restarts every time...
.ain-0 with a poti works also...
and the counter works!!!
Big thank to you, Dominik!
Friday I set up a second encoder, I will tell you if all works!
Best regards
Marcel
4 years 2 months ago - 4 years 2 months ago #249476 by zarfld
Hi Matze,
I'm glad to hear that.
do you think we might need to extend that as described in chapter "4.5 Encoder" of www.linuxcnc.org/docs/2.2/HAL_User_Manual.pdf ?
calculating "postion" using parameter "scale" should be a short one.
i can imagine that at some point "reset" might be needed, there is a PK_EncoderValuesSet() which we could use to reset the counter to 0 on pokeys for that task.
for "index-enable" i think it will be not that easy to get the next-pulse directly, maybe i just use the next loop when "counter"-value changed. (as a workaround)
for velocity we would also need to get timers involved which might get a bit complicated, but nut sure if it will be needed at this time.
(i anyway planned to do that on my pokeys.comp on github)
BR
dominik
****** edit ***********
File Name: pokeys_202...-11.comp
File Size:2.55 KB
(please note: when doing reset with current pokeyslib it's not yet possible to write/reset single encoder values to device - so i might expect issues depending if some encoders moved between ReadEncoders&WriteEncoders)
Time to create page: 0.069 seconds
