- Thank you received: 4153
If you review the errors, it is failing during the build process.
I have the same issue.
so it seems that pokeyslib commit "Merge of updated PoKeysLib to public repository"(2022-06-23) includes a change for PoKeysLibDevicePoKeys57Industrial.c, which might cause that problem.PoKeysLibDevicePoKeys57Industrial.c: In function ‘PK57i_SearchDevice’:
PoKeysLibDevicePoKeys57Industrial.c:221:12: warning: implicit declaration of function ‘GetBroadcastAddresses’ ...
#if defined(__FreeBSD__) || defined(BSD) || defined(__APPLE__) || defined(__linux__)
#define USE_GETIFADDRS 1
#define SOCKADDR struct sockaddr
#include <ifaddrs.h>
uint32 SockAddrToUint32(struct sockaddr * a)
return ((a)&&(a->sa_family == AF_INET)) ? ntohl(((struct sockaddr_in *)a)->sin_addr.s_addr) : 0;
#endif
ozisthebest@debian:~/mbosnak-pokeyslib-7a079bad8dbe$ sudo make -f Makefile.noqmake install
[sudo] password for ozisthebest:
gcc -fPIC -c -o PoKeysLibCore.o PoKeysLibCore.c
gcc -fPIC -c -o PoKeysLibCoreSockets.o PoKeysLibCoreSockets.c
