- Thank you received: 3
orpokeys.[DevID].digin.[PinID].in bit State of the hardware input
pokeys.[DevID].digin.[PinID].in-not bit Inverted state of the input.
if you just comment the these two lines then only the pins are being createdpokeys.[DevID].digout.[PinID].out
but the bit digitalIn or digital out are not read. (you would need to uncomment the lines 2319 and 2325 to get the digitalinputs updated)pokeys.[DevID].Pins.[PinID].DigitalValueGet
pokeys.[DevID].Pins.[PinID].DigitalValueSet
but i would suggest just to use the newly named digital inputs in your HAL-Fileif (DigitalIOGet = true) { if (dev->Pins.DigitalValueGet == 0) { //Pins_DigitalValueGet(i)=false; digin_in(i) = false; digin_in_not(i) = true; } else { //Pins_DigitalValueGet(i)=true; digin_in(i) = true; digin_in_not(i) = false; } }
