Pokeys_homecomp EncoderSearch / Encoder Arm Topic: Pos_Fb Following errors
9 years 7 months ago - 9 years 7 months ago #89855 by DavidJ
Replied by DavidJ on topic Pokeys
Thanks - not much clearer though. I'll re-check the PoKeys site for information. (EdIt : that's all rather confusing too - not clear which file or files I need).
When use say 'use' - am I supposed to put that command in a file ? (which one, which directory?).
What is the 'component' that I'm supposed to load?
What do I do with the code from first post?
I'm sure it's obvious once you know, but I'm clearly missing some basic knowledge. This reminds me why I've abandoned Linux several times before - great applications, very tricky to get started from zero base.
Last edit: 9 years 7 months ago by DavidJ.
9 years 7 months ago - 9 years 7 months ago #89861 by fixer
Replied by fixer on topic Pokeys
Polabs had the step by step instructions on their blog, but the site is currently dead. I attached pokeys lib compiling procedure in first post.
basically you need to do:
1. install libusb
2. download and compile pokeys library
3. compile my HAL component
4. set "udev" rules for your usb device
after that, you can include pokeys component in your HAL file as IO device.
read that:
linuxcnc.org/lucid/docs/2.6/html/hal/basic_hal.html
linuxcnc.org/docs/html/hal/comp.html
Last edit: 9 years 7 months ago by fixer.
9 years 7 months ago #89889 by DavidJ
Am beginning to see at least some of what to do. I think I follow the bit about PoKeys library.
The line "sudo halcompile ./pokeys.comp"
Does the file name that I copy your driver code into have to be named to match part of that command ? Is there a preferred location to place your code in, or doesn't it matter?
The multi-line command commencing gcc - does that have to be run from a particular directory ?
Not sure I understand 'set "udev" rules' yet.
9 years 7 months ago #89896 by andypugh
Replied by andypugh on topic Pokeys
DavidJ wrote: The line "sudo halcompile ./pokeys.comp"
Yes, the file should be called "pokeys.comp". .comp is a file format that is converted into standard C-code by the LinuxCNC utility "halcompile". Normally halcmompile can also compile and install the .comp file directly, but it seems that this component needs some special compiler options to make it work.
The "./" means "in this directory" so you need to run the halcompile command from the same directory that you saved the pokeys.comp file into.
The multi-line command is the step that compiles the HAL component into an executable. It needs to be run from the same directory as the .c file created by the first stage ended up in.
This is the step that gives the new component permission to handle the USB device.
9 years 7 months ago #89985 by DavidJ
So the "udev" bit - do I need to be looking for general Linux information to help me with that, or is it LinuxCNC specific?
9 years 7 months ago - 9 years 7 months ago #90010 by fixer
It is linux thing, on the second page of this topic.
I will add some additional information in first topic, so it will be more clear for begginers.
REEEN wrote: Finally I got it!
I needed to create a new udev rule:
Create a new file in the /etc/udev/rules.d named 90-usb-pokeys.rules with the following contents:
SUBSYSTEM=="usb", ATTRS{idVendor}=="1dc3", ATTRS{idProduct}=="1001", GROUP="plugdev", MODE="664"
Save the file, then execute
udevadm control --reload-rules
That's it!
The following user(s) said Thank You: robins
