Pokeys_homecomp EncoderSearch / Encoder Arm Topic: Pos_Fb Following errors
10 years 10 months ago #67460 by fixer
Replied by fixer on topic Pokeys
You set the device serial in devSerial HAL pin.
10 years 10 months ago #67461 by REEEN
Replied by REEEN on topic Pokeys
how can I find out my device serial ?
10 years 10 months ago #67466 by REEEN
Is it also possible to access the outputs of the extbus board the poextoc16 ?
10 years 10 months ago #67510 by fixer
well, I only use it for encoders and input pins. It could be added though... look at the link in my first post on how to use the library.
10 years 9 months ago #67709 by REEEN
Thank you !
I found out how to use the bus with the library, I only have one problem left, I can not connect to the device, the serial number is written on the board, i set the halpin devSerial to this number, but it won't connect ..... Any Ideas ?
10 years 9 months ago #67713 by andypugh
Replied by andypugh on topic Pokeys
I haven't tried this, but lsusb should list the info you need.
if you get "command not found" then sudo apt-get install usbutils
The following user(s) said Thank You: LAUSCH
Time to create page: 0.129 seconds
