updating to lcnc 2.8-dev
- sir_wolf_art
21 Apr 2019 16:23 #131406
by sir_wolf_art
updating to lcnc 2.8-dev was created by sir_wolf_art
So I have been rebuilding my linuxcnc with ubuntu budgie 18.04.2 LTS with kernel 4.18.16-rt9 #1 SMP PREEMPT RT.
It has not been easy doing this rebuilding, getting the OS with the kernel build seemed easy (if it really worked and is doing what is supposed to) but the install of linuxcnc has not been as easy. I have run into some issues with updating my .hal and .ini files and getting them to run on Lcnc 2.8-dev.
I have Lcnc built but not installed yet, I am just running it out of the scripts folder for now. Once I have everything running as it should with the hardware I hope to use. I want to move forward with the install.
Right now I have rebuilt my config files for 2.8 in hopes of making it easier to edit them down the road for newer hardware like Mesa boards or if I build other CNC machines.
However, the issue I have run into is this werd error that Lcnc is spitting out.I can’t really find anything on the error and I know it worked in 2.7. Looking in the the “Updating LinuxCNC” doc for 2.8, I cant find if there was a changes to the hal wording. All of the changes in the .ini that where listed have been make.
I have included all the files with log of the term output.
PS: What's up with this “Note” Lcnc is outputting as well?
./axises.hal:13: Pin 'axis.0.motor-pos-cmd' does not existI have included all the files with log of the term output.
Note: Using POSIX realtimePlease Log in or Create an account to join the conversation.
- Thank you received: 5316
21 Apr 2019 16:29 - 21 Apr 2019 16:30 #131407
Replied by PCW on topic updating to lcnc 2.8-dev
Normally if you have been running 2.7, the first time you run 2.8, a script detects that you have a 2.7
configuration and fixes various hal and ini names and settings like the change from
"axis.N.motor.xxxx" to "joint.N.motor.xxxx"
Did this script not run on your 2.7 configuration?
Last edit: 21 Apr 2019 16:30 by PCW.
- sir_wolf_art
21 Apr 2019 16:49 - 21 Apr 2019 17:04 #131409
by sir_wolf_art
Replied by sir_wolf_art on topic updating to lcnc 2.8-dev
No it did not run. It ran on the old config files but it did not work not sure why, maybe because the old ones where a mess. So thats is why i rebuild the the config, using what the script changed and what was in the “Updating LinuxCNC” doc for 2.8. the script did not run this time after the making the new config. Is there a way to force the script to run on the new files?
I can post the old files that the script did run but there have the same issue but with “axis.5”.
Last edit: 21 Apr 2019 17:04 by sir_wolf_art.
- Thank you received: 4141
21 Apr 2019 18:39 #131416
Replied by rodw on topic updating to lcnc 2.8-dev
Why don't you just run up stepconf again and make a basic working config? Then cut and paste your settings from ini to the new format and add any personalised stuff in your hal file?
- sir_wolf_art
21 Apr 2019 18:45 #131417
by sir_wolf_art
i would run it but it is not listed.
wolf@5-Axis-linuxCNC:~/linuxcnc-dev/scripts$ ls
decode_dmesg halreport linuxcnc.in pyvcp_demo simulate_probe
get-deb-component-from-git halrun linuxcnc_info realtime swish
get-version-from-git halrun.in linuxcncmkdesktop realtime.in torture.py
githelper.sh haltcl linuxcncmkdesktop.in rip-environment travis-build-test.sh
gladevcp_demo haltcl.in linuxcnc_var rip-environment.in travis-install-build-deps.sh
halcmd_twopass latency-histogram linuxcnc_var.in rtapi.conf update_ini
halcmd_twopass.in latency-plot monitor-xhc-hb04 rtapi.conf.in version-is-release
hal_demo latency-test moveoff_gui runtests xhc-hb04-accels
hal-histogram linuxcnc platform-is-supported sim_pin
wolf@5-Axis-linuxCNC:~/linuxcnc-dev/scripts$ Please Log in or Create an account to join the conversation.
- KCJ
- Thank you received: 267
22 Apr 2019 01:16 #131445
by KCJ
Replied by KCJ on topic updating to lcnc 2.8-dev
You can force the update script to run by changing the config version in the INI file.
For current master the INI version is 1.1 so will look like this:
Try removing the version option or changing it to a lower number.
Cheers!
Kurt
[EMC]
VERSION = 1.1Try removing the version option or changing it to a lower number.
Cheers!
Kurt
- sir_wolf_art
22 Apr 2019 03:32 #131451
by sir_wolf_art
ok i got the script to run but got new errors and not sure of what to make of this????
wolf@5-Axis-linuxCNC:~/linuxcnc-dev/scripts$ ./linuxcnc
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/wolf/linuxcnc-dev/configs/lcnc_2.8v_5_axis_mill'
Machine configuration file is '5_axis_mill.ini'
halfiles = ['main.hal', 'pinout.hal', 'axises.hal', 'other.hal', 'HY_VFD.hal', 'custom_postgui.hal', 'touchy.hal']
halpaths = ['/home/wolf/linuxcnc-dev/configs/lcnc_2.8v_5_axis_mill/main.hal', '/home/wolf/linuxcnc-dev/configs/lcnc_2.8v_5_axis_mill/pinout.hal', '/home/wolf/linuxcnc-dev/configs/lcnc_2.8v_5_axis_mill/axises.hal', '/home/wolf/linuxcnc-dev/configs/lcnc_2.8v_5_axis_mill/other.hal', '/home/wolf/linuxcnc-dev/configs/lcnc_2.8v_5_axis_mill/HY_VFD.hal', '/home/wolf/linuxcnc-dev/configs/lcnc_2.8v_5_axis_mill/custom_postgui.hal']
check_config: (trivkins kinematics) WARNING:
Unspecified [JOINT_0]MAX_VELOCITY, default used: 1.0
Unspecified [JOINT_0]MAX_ACCELERATION, default used: 1.0
Unspecified [JOINT_1]MAX_VELOCITY, default used: 1.0
Unspecified [JOINT_1]MAX_ACCELERATION, default used: 1.0
Unspecified [JOINT_2]MAX_VELOCITY, default used: 1.0
Unspecified [JOINT_2]MAX_ACCELERATION, default used: 1.0
Unspecified [JOINT_3]MAX_VELOCITY, default used: 1.0
Unspecified [JOINT_3]MAX_ACCELERATION, default used: 1.0
Unspecified [JOINT_4]MAX_VELOCITY, default used: 1.0
Unspecified [JOINT_4]MAX_ACCELERATION, default used: 1.0
Unspecified [JOINT_5]MAX_VELOCITY, default used: 1.0
Unspecified [JOINT_5]MAX_ACCELERATION, default used: 1.0
Unspecified [AXIS_X]MAX_VELOCITY, default used: 1.0
Unspecified [AXIS_X]MAX_ACCELERATION, default used: 1.0
Unspecified [AXIS_A]MAX_VELOCITY, default used: 1.0
Unspecified [AXIS_A]MAX_ACCELERATION, default used: 1.0
Unspecified [AXIS_Y]MAX_VELOCITY, default used: 1.0
Unspecified [AXIS_Y]MAX_ACCELERATION, default used: 1.0
Unspecified [AXIS_B]MAX_VELOCITY, default used: 1.0
Unspecified [AXIS_B]MAX_ACCELERATION, default used: 1.0
Unspecified [AXIS_Z]MAX_VELOCITY, default used: 1.0
Unspecified [AXIS_Z]MAX_ACCELERATION, default used: 1.0
check_config: (trivkins kinematics) ERROR:
[JOINT_0]MAX_LIMIT < [AXIS_X]MAX_LIMIT (400.0 < 400.0 400.0)
[JOINT_3]MAX_LIMIT < [AXIS_A]MAX_LIMIT (9999.0 < 9999.0 9999.0)
[JOINT_1]MAX_LIMIT < [AXIS_Y]MAX_LIMIT (300.0 < 300.0 300.0)
[JOINT_4]MAX_LIMIT < [AXIS_B]MAX_LIMIT (9999.0 < 9999.0 9999.0)
[JOINT_2]MAX_LIMIT < [AXIS_Z]MAX_LIMIT (50.001 < 50.001 50.001)
check_config validation failed
LinuxCNC terminated with an error. You can find more information in the log:
/home/wolf/linuxcnc_debug.txt
and
/home/wolf/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
22 Apr 2019 05:28 #131457
If you run Linuxcnc from the command line what is printed on the terminal window? There's usually an error there that pinpoints the fault. (Says he who just spent afew hours going around the twist trying to resolve similar errors on an new build!
- sir_wolf_art
22 Apr 2019 05:42 #131459
by sir_wolf_art
right now the now way to run lcnc is the terminal I have NOT installed lcnc JUST built it so all the errors are what has been print in the terminal.
i have not installed lcnc yet because i dont think my kernel is working right because mouse well stop random for a sec, plus i get this note each time i run something that is part of lcnc, but one issue at a time.
- pl7i92
- Thank you received: 358
22 Apr 2019 07:00 #131463
by pl7i92
Replied by pl7i92 on topic updating to lcnc 2.8-dev
only the main mashine HAL files are updatet its a mess on halui files postgui all has changed
Time to create page: 0.303 seconds
