updating to lcnc 2.8-dev
22 Apr 2019 08:53 #131504 by tommylight
Replied by tommylight on topic updating to lcnc 2.8-dev
Note: Using POSIX realtime
That is correct, meaning your realtime kernel is running properly.
22 Apr 2019 09:06 #131507 by pl7i92
Replied by pl7i92 on topic updating to lcnc 2.8-dev
tommy can you have uspace mesa ethernet also on the 18.04 ubuntu running
22 Apr 2019 09:34 #131512 by tommylight
Yes of course. You can use the tutorial to compile it, or search the web for a ready made Preempt-RT kernel.
I lately found a kernel made for high end audio systems running linux that works on Linux Mint very nicely.
The only thing i do not like when compiling a new kernel is it gets very big and takes long to boot, as it will install drivers for almost anything possible. The good thing is once you compile a kernel, make debs for it and save them to a USB, later on you can use those debs to install the kernel in 3 minutes instead of several hours.
