- Configuring LinuxCNC
- HAL
- Parallel port problems on new build; pins 14 and 16 not working for spindle
- trebuchetguy
03 Jul 2019 12:39 #138549
by trebuchetguy
Parallel port problems on new build; pins 14 and 16 not working for spindle was created by trebuchetguy
This is my first post on this forum, please let me know if it's in the wrong category, and I thank you in advance for your assistance.
I have a CNC mill setup using a PMDX-126 and PMDX-107. I'm using two parallel ports. It worked great with an old PCI parallel port card for about a year, but I had to rebuild the PC recently and had to switch to a new PCIe card.
With the new PC (same configuration as the old PC), everything seems to work (X, Y, Z movement), except for the spindle control using pins 14 and 16 on the main parallel port. HAL seems to think that it's sending the correct signal to those pins, but my multi-meter and the PMDX-126 seem to disagree.
The PMDX-126 is hardwired to use pins 14 and 16 for spindle control, so I need to get those specific pins working.
I've tried two different dual parallel cards with no success; same problem with both.
-First attempt: www.amazon.com/gp/product/B00EA0WKDG/ref...05_s01?ie=UTF8&psc=1
-Second attempt: www.amazon.com/gp/product/B0090EE12U/ref...00_s00?ie=UTF8&psc=1
I think my issue is similar to this one: www.forum.linuxcnc.org/38-general-linuxc...port-pin-1-14-16-and
Am I out of luck and need to buy yet another card? Or is there something I can do to get one of these cards working? Please let me know if you need to see any specific configurations.
Many thanks for any assistance!
- Thank you received: 5336
03 Jul 2019 13:43 - 03 Jul 2019 13:43 #138559
Replied by PCW on topic Parallel port problems on new build; pins 14 and 16 not working for spindle
Did you try setting the mode of the hal_parport driver to "epp"?
If that does not work, I would take Andy's advice on the last port of the forum thread you linked,
and add a stiff pullup resistor to pins 14 and 16 of the parallel port.
(perhaps on the back of the parallel ports DB25)
Last edit: 03 Jul 2019 13:43 by PCW.
- trebuchetguy
03 Jul 2019 15:08 #138563
by trebuchetguy
Replied by trebuchetguy on topic Parallel port problems on new build; pins 14 and 16 not working for spindle
Thanks for the quick response; I did try setting the driver to epp, but then when I start axis, it throws a "cannot find parallel port" (or something like that) error.
I'll try to see where I can easily add a pull-up resistor on the PMDX-126.
Thanks!
Thanks!
03 Jul 2019 15:11 #138565
Are you sure you got the hal_parport syntax correct?
(throwing an error suggests a syntax problem )
- trebuchetguy
03 Jul 2019 15:13 #138566
by trebuchetguy
Good question, let me double check. I thought it was, but maybe I did something wrong.
- trebuchetguy
03 Jul 2019 16:12 #138571
by trebuchetguy
Re: EPP, this is what I have in my HAL config:
loadrt hal_parport cfg="0 epp 1 epp"
It gives this error (twice) upon AXIS start: "Linux parallel port @65535 not found"
If I change it to: "loadrt hal_parport cfg="0 out 1 out"" It starts up without an error.
However, both configs still seem to allow XYZ movement without a problem.
03 Jul 2019 16:29 #138574
Sounds like maybe a parsing bug in hal_parport
(the port index fails when epp is selected )
Did you try with port addresses instead of indexes?, that might be a
work-around
work-around
The following user(s) said Thank You: trebuchetguy
- trebuchetguy
03 Jul 2019 21:49 #138586
by trebuchetguy
Thanks for your help.
loadrt hal_parport cfg="0xe030 epp 0xe010 epp" yields the same "Linux parallel port @65535 not found" error.
This weekend I'll try to get a pull up resistor in place. I should be pulling it up to 3.3v correct?
03 Jul 2019 22:25 #138589
I think a pullup to 3.3V would be safest
I cannot duplicate your error but my hardware is quite different=1 port on motherboard
peter@dc7800:~/linuxcnc/configs$ halrun
halcmd: loadrt hal_parport cfg=" 0 epp"
Note: Using POSIX realtime
config string ' 0 epp'
04 Jul 2019 06:58 #138618
"epp" is not a valid modifier in the parport cfg. You can use "in" or "out" or "x"
The EPP setting is done in the BIOS, not in HAL.
Replied by andypugh on topic Parallel port problems on new build; pins 14 and 16 not working for spindle
- HAL
Time to create page: 0.260 seconds
