- Thank you received: 79
Gnevko wrote: Of course mechanical, but a closed loop system with linear encoders should solve exactly this problem or not?
PCW wrote: What is the following error when you read the 0.03 mm position error?
(that is, what is joint.0.f-error?)
A 0.03 mm error that HAL / LinuxCNC sees should result in a motion of
2.7 mm/s to correct the position error with your current tuning parameters
( 0.03 * 90 = 2.7 mm/s )
