New component for keyboards and panels.
3 years 19 hours ago #284225
Replied by andypugh on topic New component for keyboards and panels.
If you are running with Mesa cards then you probably are not running a base thread.
It's unlikely that you are running out of time, but comparing the value of the hal parameter servo-thread.tmax with the servo thread period might give some idea how much CPU time is left for other services.
The following user(s) said Thank You: COFHAL
- COFHAL
- Thank you received: 62
2 years 11 months ago #284734
by COFHAL
Replied by COFHAL on topic New component for keyboards and panels.
- COFHAL
2 years 11 months ago #284735
by COFHAL
2 years 11 months ago #284736
960575 does seem worryingly close to 1000000.
I wonder if there is any scope for pruning your servo thread tasks?
halcmd show funct
Will give a snapshot of which servo-thread functions are using a lot of time.
halcmd show funct
- COFHAL
2 years 11 months ago #284829
by COFHAL
This is what appears when I run halcmd show funct. I attach the entire file by running just halcmd show.
- abdulasis12
- Thank you received: 8
2 years 5 months ago #300721
by abdulasis12
Replied by abdulasis12 on topic New component for keyboards and panels.
Thank you COFHAL, for share link to here topic
this is my old topic forum.linuxcnc.org/49-basic-configuratio...ey-how-to-map-number
I start with try from link : linuxcnc.org/docs/2.8/html/man/man1/sendkeys.1.html
all look good except ls -l /dev/uinput
In link show : crw-rw----
But my Terminal show : crw
only (no rw)
I try open linuxcnc from terminal
cannot /dev/uinput. Suggest chmod 666 /dev/uinput
How to can access chmod 666 ?
FYI:
- I use 7i73 matrixkey 8x8 (good work)
- I already add loadusr -W sendkeys config=16t2
net scancodes hm2_7i73.0.0.keycode => sendkeys.0.keycodesetp sendkeys.0.scan-event-00 34 # Key G
setp sendkeys.0.scan-event-01 2 # Key 1
setp sendkeys.0.scan-event-02 3 # Key 2
setp sendkeys.0.scan-event-03 4 # Key 3
setp sendkeys.0.scan-event-04 50 # Key M
setp sendkeys.0.scan-event-05 05 # Key 4
setp sendkeys.0.scan-event-06 06 # Key 5
setp sendkeys.0.scan-event-07 07 # Key 6
setp sendkeys.0.scan-event-08 31 # Key S
setp sendkeys.0.scan-event-09 8 # Key 7
setp sendkeys.0.scan-event-10 9 # Key 8
setp sendkeys.0.scan-event-11 10 # Key 9
setp sendkeys.0.scan-event-12 20 # Key T
setp sendkeys.0.scan-event-13 11 # Key 0
setp sendkeys.0.scan-event-14 52 # Key Dot
setp sendkeys.0.scan-event-15 14 # Backspace
setp sendkeys.0.pin-event-00 29 # Left Ctrl
setp sendkeys.0.pin-event-01 57 # Space
only (no rw)
FYI:
Time to create page: 1.084 seconds
