I can't get spindle speed feedback
- Servimet
23 Dec 2021 17:19 - 23 Dec 2021 17:20 #229835
by Servimet
I can't get spindle speed feedback was created by Servimet
Estimated for some reason I can't get spindle speed feedback !!
the rpm bar in the linux control is dead
I have a 7i92m-7i77 mesa set
I am very new to the linux world
I have tried several examples of hal files that I took from this forum and nothing worked so far
I attach my hal file
From already thank you very much
Last edit: 23 Dec 2021 17:20 by Servimet.
- Thank you received: 2181
23 Dec 2021 21:01 #229852
Replied by cmorley on topic I can't get spindle speed feedback
Please post all your config files.
- Hakan
- Thank you received: 482
24 Dec 2021 05:40 - 24 Dec 2021 05:40 #229876
by Hakan
Replied by Hakan on topic I can't get spindle speed feedback
counter_mode 1?
If it is a quadrature encoder, which I think most are, it should be counter_mode 0
Last edit: 24 Dec 2021 05:40 by Hakan. Reason: mixed up 0 and 1
- Servimet
24 Dec 2021 07:02 - 24 Dec 2021 07:14 #229880
by Servimet
Replied by Servimet on topic I can't get spindle speed feedback
Dear attached all my configuration files
I still don't have rpm in the linux panel
I appreciate your help
Last edit: 24 Dec 2021 07:14 by Servimet.
- Clive S
- Thank you received: 486
24 Dec 2021 07:05 #229881
by Clive S
Where have you attached them ?
Replied by Clive S on topic I can't get spindle speed feedback
- Servimet
24 Dec 2021 07:22 - 24 Dec 2021 08:39 #229884
by Servimet
Last edit: 24 Dec 2021 08:39 by Servimet.
- Servimet
24 Dec 2021 07:25 - 24 Dec 2021 09:01 #229885
by Servimet
Attachment not found
Last edit: 24 Dec 2021 09:01 by Servimet.
- Servimet
24 Dec 2021 07:36 #229886
by Servimet
Hi Hakan, this is the moment, I'm editing the file extension to be able to upload it to the forum. I would appreciate your help in a review.
- Servimet
24 Dec 2021 07:38 #229887
by Servimet
Hello Clive S, this time I am editing the extension of the configuration files to be able to upload it all to the forum
- Clive S
24 Dec 2021 08:07 - 24 Dec 2021 08:19 #229889
by Clive S
Is it correct that the only file Sabre_1000_2021-12-24.hal is the only one with any data in it.
It might be better to zip the complete config up.
Can you also give a description of the machine ie. how many axis XYZ does it have a A axis
as the HAL file seems to have a few duplications
The ini file is missing as well.
Last edit: 24 Dec 2021 08:19 by Clive S.
Time to create page: 0.197 seconds
