7i76 MPG cant get reading
- Kasper-001
- Thank you received: 5
19 Feb 2022 12:55 #235341
by Kasper-001
Replied by Kasper-001 on topic 7i76 MPG cant get reading
its working now, but is there any issue/danger doing this ?
- Thank you received: 5337
19 Feb 2022 13:49 #235344
Replied by PCW on topic 7i76 MPG cant get reading
You do lose the isolation between the field I/O section and the step/dir/PC side
If this is an issue you could use a 5V regulator running from the 24V side for the MPG
The following user(s) said Thank You: Kasper-001
