Trying to Configure Dual Y Axis
3 years 3 months ago #275524 by Routerworks
Should I change the X and Z axis as well?
3 years 3 months ago #275525 by JPL
Replied by JPL on topic Trying to Configure Dual Y Axis
Just edited my post above.
Please read the second part as homing will not work the way it is now.
3 years 3 months ago #275526 by JPL
Yes
But again a bunch of thing are missing in your config.
see here for the minimum needed :https://linuxcnc.org/docs/html/config/ini-homing.html#_immediate_homing
3 years 3 months ago #275527 by Routerworks
Your saying it should be:
Joint 0 should read HOME_SEQUENCE=1
and
Joint 3 should read HOME_SEQUENCE=3
Joints 1 and 2 should read HOME_SEQUENCE=-2
3 years 3 months ago #275528 by JPL
and
Yes, but you MUST also have ALL 5 lines mentioned there under 6.13 immediate homing. This is
  1. HOME_SEARCH_VEL = 0
  2. HOME_LATCH_VEL = 0
  3. HOME_USE_INDEX = NO
  4. HOME equals to HOME_OFFSET
  5. HOME_SEQUENCE = 0 (or other valid sequence number)
3 years 3 months ago #275529 by Routerworks
I am just reading that from your link. Do I put this under each axis? Do I need to put sequence number?
Time to create page: 0.413 seconds
