Trying to Configure Dual Y Axis
3 years 3 months ago - 3 years 3 months ago #275460 by tommylight
Nope, no report.
Yay, report! :)
Last edit: 3 years 3 months ago by tommylight.
3 years 3 months ago #275461 by Routerworks
Do you have it now?
3 years 3 months ago #275464 by tommylight
From your hal file:
net ystep => parport.0.pin-04-out
then
net y0pos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net y0pos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net y0step <= stepgen.1.step
net y0dir <= stepgen.1.dir
net y0enable joint.1.amp-enable-out => stepgen.1.enable
That will not work, ystep requires ypos, ystep, ydir, yenable, etc, not y0pos
this is all over the hal file, so to many things to fix.
Lets go back, you have a parallel port, so limited IO, do you want:
-to have limit switches on all axis/joints?
-do you need to square the gantry or is it stiff enough to stay trammed?
-do you want to have both motors/drives for Y axis run at the same time, even when jogging and before homing the machine?
3 years 3 months ago - 3 years 3 months ago #275469 by JPL
Replied by JPL on topic Trying to Configure Dual Y Axis
From the hal file:
setp parport.0.pin-01-out-invert 1
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net ystep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net ydir => parport.0.pin-09-out
net spindle-cw => parport.0.pin-14-out
net spindle-pwm => parport.0.pin-16-out
net xenable => parport.0.pin-17-ou
So, ystep and ydir is repeated:
ystep goes to pins 04 and 08
ydir goes to pins 05 and 09
BUT no 'y0' or 'y1'
Then after that you started using y0step and y1step
net y0dir <= stepgen.1.dirAND
net y1step <= stepgen.2.step
net y1dir <= stepgen.2.dir...
Last edit: 3 years 3 months ago by JPL.
3 years 3 months ago - 3 years 3 months ago #275470 by JPL
Not 100% sure, maybe Tommy could confirm but I think that one of the first thing to do is:
replace net ystep => parport.0.pin-04-out    with   net y0step => parport.0.pin-04-out
replace net ydir => parport.0.pin-05-out       with   net y0dir => parport.0.pin-05-out
replace net ystep => parport.0.pin-08-out    with   net y1step => parport.0.pin-08-out
replace net ydir => parport.0.pin-09-out       with   net y1dir => parport.0.pin-09-out
Last edit: 3 years 3 months ago by JPL. Reason: Bold to make it easier to read
3 years 3 months ago #275472 by Routerworks
Good catch. I'll change them.
Time to create page: 0.311 seconds
