Trying to set up position control mode
- jblanscett
05 Mar 2026 18:45 #343914
by jblanscett
Replied by jblanscett on topic Trying to set up position control mode
DRO updates to the inputed position about a second after .1 inches is inputted and the motor continues after that. The DRO doesn't update again until another input is entered.
- Thank you received: 5332
05 Mar 2026 18:59 #343915
Replied by PCW on topic Trying to set up position control mode
OK so that may still be an electrical/wiring issue
(if the DRO does not move but the motors move)
- jblanscett
05 Mar 2026 19:18 #343916
by jblanscett
Okay, is there a way to verify that it is an electrical/wiring issue?
05 Mar 2026 19:56 - 05 Mar 2026 20:58 #343917
Might look at the step pulse train with an oscilloscope.
Also is it possible the servo drive is not set to position mode?
Last edit: 05 Mar 2026 20:58 by PCW.
- jblanscett
06 Mar 2026 13:12 #343940
by jblanscett
What should I be looking at with the oscilloscope? I have checked that our signal looks like it is supposed to and when I press the continuous jog, it stops about when I release the continuous jog and the motor keeps spinning.
We went through a back and forth with Yaskawa before this to confirm it is in position mode, because that was our first thought. What I don't really understand is how the 7i95 board knows it is supposed to generate position based step generation when we are sending it velocity commands?
06 Mar 2026 14:29 #343941
If the motor keeps turning without step pulses, this is a root of the problem
and there's nothing on the LinuxCNC/7I95 side that can fix this.
It really sounds like the drive is in velocity mode.
- jblanscett
06 Mar 2026 18:47 #343949
by jblanscett
Okay, we will try to confirm that it is our servopack.
Does anybody have experience with position control mode on the SGDH-10AE or another Yaskawa sigma II series servopack?
Time to create page: 0.146 seconds
