How to right sequence run - pause -stop
27 Apr 2011 15:21 #9402 by andypugh
Replied by andypugh on topic Re:How to right sequence run - pause -stop
piasdom wrote:
this works
You astonish me.
net pause-btn toggle.0.in == pyvcp.prog-pause
net pause-btn toggle.0.in halui.program.pause
net all-paused toggle.0.out halui.program.resume
What on earth are you trying to achieve? That makes no sense at all.
The idea of toggle is that the output switches state every time you press the button. You would connect the input to the pyvcp button, and the output to the thing you want to switch.
To resume after pause, you would use an inverted version of the toggle output (which I am slightly surprised isn't a pin on the component). You can get the inverted value using:
www.linuxcnc.org/docview/html/man/man9/not.9.html
Which has an output of false if the input is true, and vice-versa.
27 Apr 2011 15:24 #9403 by BigJohnT
Replied by BigJohnT on topic Re:How to right sequence run - pause -stop
Nope only one shows depending on the state of the control pin.
halui.program.run will only work when the machine is in the auto mode.
27 Apr 2011 15:43 #9405 by piasdom
Replied by piasdom on topic Re:How to right sequence run - pause -stop
andypugh wrote:
piasdom wrote:
this works
You astonish me.
they say people that know a little about a lot are dangerous
i'll look into this :)
27 Apr 2011 15:45 #9406 by piasdom
is it in auto mode when i press axis run button ? that's when i'm
pressing pyvcp button.
27 Apr 2011 15:47 #9407 by piasdom
got his but have "NO" idea for to link to pyvcp. use <halpin>'selectimage'</halpin> ?
<image name='on' file='on.gif'/>
<image name='off' file='off.gif'/>
<vbox>
<image_bit halpin='selectimage' images='on off'/>
</vbox>
27 Apr 2011 15:49 #9408 by BigJohnT
Nope, you have to use halui.mode.auto which is the pin for requesting auto mode then to verify that auto mode is on check halui.mode.is-auto, if it is then you can press the run button.
27 Apr 2011 15:51 #9409 by BigJohnT
<vbox>
</vbox>
You could use halui.machine.is-on to toggle the images.
27 Apr 2011 15:51 #9410 by piasdom
trying to get a one button to pause and resume.
lick click once = pause
click same button again = resume
27 Apr 2011 15:55 #9411 by piasdom
<vbox>
</vbox>
[/quote]
John[/quote]
i'm having trouble seeing where to link 'selectimage' to halui.machine.is-on.
do i use 'selectimage' or the whole thing <image_bit halpin='selectimage' images='on off'/> ?
what to use as the <halpin> ???? </halpin> ?
<halpin> 'selectimage' </halpin> ?????
i meant i have no idea what the pin is.
27 Apr 2011 16:41 #9412 by piasdom
so toggle.n and not.n are not the same ?
thought someone told me to use toggle.n
Time to create page: 0.094 seconds
