Fadal Retrofit - ATC cycle
8 years 1 week ago #119255 by andypugh
Replied by andypugh on topic Fadal Retrofit - ATC cycle
Do you see anything in the terminal output?
8 years 1 week ago #119256 by COlger81
Replied by COlger81 on topic Fadal Retrofit - ATC cycle
It gives me a "sys" is not defined. But in regards to the hall sensor line, it does not give any errors.
8 years 1 week ago - 8 years 1 week ago #119257 by Nitram
Replied by Nitram on topic Fadal Retrofit - ATC cycle
Just to provide another avenue, the auto tool change in question was ultimately achieved by having the sequence run via G code but having a subset of user defined M codes which compartmentalized the whole auto tool change sequence. Within these was also the usual "check for carousel in extended position" etc fault checking.
Then these were all brought together (again via G code) and made into the full M6 sequence (the M6 itself being re-defined to run the complete tool change G code).
It was felt that there would be advantages in having compartmentalized M codes for the individual segments of the procedure in case there were any crashes during the tool change sequence so that one could call a certain M code and carry out any rectifying actions in a step by step way.
For example, I left the probe in the spindle when I executed a tool change to get the tool I needed. Not the brightest thing to do, and because I didn't want to damage to probe I hit the E Stop. So, the carousel is sitting half way out and the whole machine is somewhere in the middle of a tool change. Having the ability to call smaller subsets of the tool change sequence via user defined M codes made it easy to retrieve the probe then send the carousel back to home. In other words, sort out the error and place the machine back into a known state.
Not knowing well the way classic ladder or python integrates with LCNC, can segments of code be run outside the entirety of the program? In other words with full and complete auto tool change routine written in classic ladder, would it still be able to send the carousel back to home position using the above example? Or can it only be run linearly from start to finish?
There are a million ways to skin a cat, one way no better or worse than the other. But having seen things like this first hand, I'm glad I have the facility to call smaller M codes to fix the rare occasion of an incomplete tool change.
Last edit: 8 years 1 week ago by Nitram.
8 years 1 week ago #119258 by COlger81
Nitram, could you send your linuxcnc files?
8 years 1 week ago #119261 by andypugh
COlger81 wrote: It gives me a "sys" is not defined. But in regards to the hall sensor line, it does not give any errors.
I am pretty sure that the Python script will give up entirely at that point.
Do you see the HAL pins appear?
8 years 1 week ago #119262 by rodw
Replied by rodw on topic Fadal Retrofit - ATC cycle
Pretty sure you need to add
import sys
at the beginning of your file. I certainly had to on Windows as the output below shows
>>> sys.byteorder Traceback (most recent call last): File "<stdin>", line 1, in <module> NameError: name 'sys' is not defined >>> import sys >>> sys.byteorder 'little' >>>
I'm still very much a noob with python
Time to create page: 0.164 seconds
