linuxcnc classicladder ATC 12 tool
5 years 10 months ago #191504 by aluplastvz
Replied by aluplastvz on topic linuxcnc classicladder ATC 12 tool
Hello Andrew
I access my cnc lathe files they are a bit messy but they work so if you can help someone i will be glad
Greeting
5 years 10 months ago #191611 by Becksvill
Replied by Becksvill on topic linuxcnc classicladder ATC 12 tool
awesome
I think most of it makes sense
hey because you send me the whole config I saw all andys lathe macros.
I have not dived into glade or pyvcp much yet
if I changed all the hal connections to suit my hardware how hard do you think it would be to get the lathe conversational stuff working just on a sim? I can handle the hal connections fine I think and the ladder logic makes sense
Andrew
5 years 10 months ago #191650 by aluplastvz
Yes it is a complete configuration so it should work if you change it.
What hardware do you use?
greeting
The following user(s) said Thank You: Becksvill
5 years 10 months ago #192239 by Becksvill
I use a mesa 6i25 and 7i77 - 7i84 combo
i am pretty confortable changing mesa pin names etc. its just the pyvcp stuff that I get stuck with.
I have three weeks off over christmas and all my servos just turned up so I will attack this then and hopefully we can all work it out.
I would like to use a stock standard linuxcnc if I can rather than pathpilot
but will just see how good axis can be with the modifications
Andrew
5 years 4 months ago #212381 by Ingo
Replied by Ingo on topic linuxcnc classicladder ATC 12 tool
Hi Aluplastvz,
I found your ATC12 amazing, I tried to unzip and it gave a problem, could you send it again?
Thank you very much
Ingo
5 years 4 months ago #212837 by Ingo
Hello Aluplastvz, I was looking at your ATC12, I managed to unzip the file. Sorry for the questions, I'm learning about it… I'm making a machine very similar to yours, I managed to create the part of the spindle axes, the Hal and classicladder part, plus the ATC part I'm suffering a lot…, I thought about using your project I don't know if are you all right? More even if use how can I do to put your Hal inside my Hal machine? The Classicladder same thing? I also noticed that you used GUI Axes and I'm using Gmoccapy will I have problems?
Ingo
Time to create page: 0.156 seconds
