eccentric turning
6 years 7 months ago #159354 by andypugh
Replied by andypugh on topic eccentric turning
alkabal wrote: Or how do you use it ?
Normally, I don't. It has always mainly been a proof-of-concept. ( here is a more extreme and complicated version)
It is installed in my lathe HAL, but the only way to set the parameters is with G-code outputs (M68). I don't use it enough to need a PyVCP or Glade panel for it.
6 years 7 months ago #159360 by alkabal
Replied by alkabal on topic eccentric turning
This is crazy !
6 years 7 months ago - 6 years 7 months ago #160763 by alkabal
Hi
I like to try doing a gladevcp panel like you done for macro.
I think the staring point is converting the C axis used by sim config for use the spindle angle but for now i really don't understand how to start. Sim is not enough i need to see real machine working (without stock for starting :laugh: ).
In the parameters manual i see nothing about some _spindle_angle, but they are available from HAL
net spindle-pos <= [HMOT](CARD0).encoder.00.position net spindle-pos => spindle.0.rev
It is a job for some special feature version ?
Attached file needed by the sim config, any help are really welcome
Br
Ps : i appologize if you better like creating a new topic ?
Last edit: 6 years 7 months ago by alkabal.
6 years 7 months ago #160764 by andypugh
"some_spindle_angle" was meant to be an obvious placeholder for an actual HAL signal as I have no way to know what your HAL file uses for the spindle angle signal. Though now it appears that your HAL uses spindle-pos.
6 years 7 months ago #160772 by alkabal
I have also :
net spindle-pos-deg <= orient.orient-spindle.angle-scaled-out # degree position from 0/360 (only positive value) net spindle-orient-degree-cmd <= spindle.0.orient-angle net spindle-orient-degree-cmd => orient.orient-spindle.angle
Attached you can found my hal and ini
6 years 7 months ago #161056 by alkabal
Hi
I'm trying to understand the process, this require to link this HAL value from macro to HAL the problem is i don't found some exemple, your original lathemacro pass the value to ocode subroutine.
#net spindle-pos-deg => eoffset_per_angle.Xeoffset.angle net spindle-pos => eoffset_per_angle.Xeoffset.angle net Xeoffset-radius-ref => eoffset_per_angle.Xeoffset.radius-ref net Xeoffset-enable-in => eoffset_per_angle.Xeoffset.enable-in net Xeoffset-fnum => eoffset_per_angle.Xeoffset.fnum net Xeoffset-rfraction => eoffset_per_angle.Xeoffset.rfraction net Xeoffset-fmult => eoffset_per_angle.Xeoffset.fmult net Xeoffset-start-angle => eoffset_per_angle.Xeoffset.start-angle
-It is possible from ocode to update HAL pin ?
Or
-it is possible from macro.ui to change HAL value before send ocode ?
Or
-need to use other way like a remap/add new Gcode to interpreter ?
Or
- What did you think ?
The goal is mostly to allow me to easily turn some eccentric screw. (polygon is also something i like to be possible to do)
Br
Time to create page: 0.149 seconds
