eccentric turning
7 years 11 months ago #121661 by Peter_Cassar
Replied by Peter_Cassar on topic eccentric turning
Andy, I'm going to try for a sinusoid with at least six peaks. The hobb idea is probably the better way to go for involute gears as only the single point tool is needed ground to the pressure angle. I was thinking about threading with this method to get a lobbed thread, you're thinking ahead. With clock (cycloidal) wheels , they can be hobbed but you need a different hobb for each module and tooth to pinion leaf ratio. Most of the time we are using single wheel cutters per module which is an approximation , so it will be feasible to make a form relieved single gang cutter using the eoffsets per angle as in what we're doing here.
I just found a 40:1 worm drive reduction gearbox in the workshop (2 actually and they could be coupled) , I'll next look at a way of coupling it to the lathe headstock spindle. I'll probably drive it with an auxiliary motor.
It's all very promising.
7 years 11 months ago #121662 by andypugh
Replied by andypugh on topic eccentric turning
Peter_Cassar wrote: The hobb idea is probably the better way to go for involute gears as only the single point tool is needed ground to the pressure angle. I was thinking about threading with this method to get a lobbed thread, you're thinking ahead. With clock (cycloidal) wheels , they can be hobbed but you need a different hobb for each module and tooth to pinion leaf ratio. Most of the time we are using single wheel cutters per module which is an approximation.
Now you have made your CNC relieving lathe, making a gear hobbing machine is relatively trivial...
7 years 11 months ago #121664 by Peter_Cassar
That's on the list of things to do! That looks like a belt driven rotary axis and it works well.
7 years 10 months ago #121694 by Peter_Cassar
Here's a small pic of a sine wave modulation on the end of brass bar. I have added a reduction drive to the spindle to achieve sub 20RPM so that more than 12 peaks can be achieved.
7 years 10 months ago - 7 years 10 months ago #121695 by rodw
Replied by rodw on topic eccentric turning
Looks awesome Peter. Great to see the external offsets in action.
It would be very cool if you wrote a component that calculated the involute gear form now.
There is some background and a link to some code on git hub here:
engineering.stackexchange.com/questions/...ute-gear-calculation
Good Luck. I'm sure Andy will help you. Sadly I don't think my maths is strong enough.
Last edit: 7 years 10 months ago by rodw.
7 years 10 months ago #121699 by Peter_Cassar
Rod, I was thinking that as I watched the cutting action, it's not far off how a gear could be produced.
Time to create page: 0.244 seconds
