eccentric turning
7 years 11 months ago #121447 by Peter_Cassar
Replied by Peter_Cassar on topic eccentric turning
That sounds like a good way to go. I haven't checked yet but will the dev version remain separate from the live version if I build on the controller? Sounds like it will from your description.
7 years 11 months ago #121448 by rodw
Replied by rodw on topic eccentric turning
Yes, if you've followed the default install everything is contained in your home folder in the ~/linuxcnc-dev folder and the default 2. 7 install is installed somewhere deeper in the bowels of Linux Thats why the rip-environment script is required to tell Linux where to find everything
7 years 11 months ago #121449 by Peter_Cassar
That's perfect then and I'll start it on the controller now.
7 years 11 months ago #121456 by Peter_Cassar
I've built LinuxCNC 2.8 on the controller, run the tests etc and no errors but I seem to have a problem running my standard config. It seems there's been a change in the AXIS/JOINT specs in the ini file and when I run my config the whole OS crashes to a black screen. I have made changes to the ini or at least the script converted it. What version info should I have in the config ini? I wasn't expecting this.
7 years 11 months ago #121460 by andypugh
Replied by andypugh on topic eccentric turning
Crashing to a black screen is certainly unexpected.
Can you run the 2.8 sample configs that are in the linuxcnc-dev/configs folder?
7 years 11 months ago #121462 by Peter_Cassar
Andy, I need to stop LinuxCNC from picking up the old configs as it runs the script to convert them. I'm not sure what's going on but it's pointing at linuxcnc/configs rather than the dev version. I ran out of time this evening to do more testing but the crash is pretty nasty with some sort of core dump and an unresponsive machine. I need to pull the power plug and do a hard reboot.
Time to create page: 0.135 seconds
