eccentric turning
7 years 11 months ago #121409 by andypugh
Replied by andypugh on topic eccentric turning
Normally you can get 2,8 (which is the unstable development version) from buildbot.linuxcnc.org, but that appears to be down at the moment.
7 years 11 months ago #121411 by Peter_Cassar
Replied by Peter_Cassar on topic eccentric turning
Ok then I'll keep checking when it comes back online.
7 years 11 months ago #121412 by rodw
Replied by rodw on topic eccentric turning
or build from source.
linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
Personally, I think its worth the effort to give this a try. The only annoying bit is finding the dependencies.
Then you are always up to date by typing about 3 lines from the terminal window (give or take any introduced bugs)...
7 years 11 months ago #121414 by Peter_Cassar
Thanks for the build suggestion. I'll give it a go.
7 years 11 months ago #121443 by Peter_Cassar
Thanks Guys I have successfully built 2.8 on my laptop , just need to figure out how to move it onto the controller for the lathe. I must say the dependencies were little tricky. Perhaps I should replicate the process on the dedicate controller.
7 years 11 months ago #121446 by rodw
Good Work!
I have not tried it, but I think you could replicate the process on your controller and not install it to the menu system. Then just use run in place. That means you will need to run linuxcnc from the command line (but run the rip-environment script first). Worst case you would need to reboot to go back to 2.7 to reset the environment variables.
I have to say I have always run my machine as a run in place install.
The following user(s) said Thank You: Peter_Cassar
Time to create page: 0.419 seconds
