eccentric turning
7 years 11 months ago #121401 by andypugh
Replied by andypugh on topic eccentric turning
I don't think I actually have anything to hand.
But it is pretty easy to write from scratch.
Which version of LinuxCNC are you currently on?
7 years 11 months ago #121402 by Peter_Cassar
Replied by Peter_Cassar on topic eccentric turning
thanks Andy, I use 2.7.3 will upgrade if needed.
7 years 11 months ago #121403 by andypugh
If you update to 2.8 then you can use:
linuxcnc.org/docs/devel/html/motion/external-offsets.html
In fact there is already a component to do what is required:
linuxcnc.org/docs/devel/html/man/man9/eoffset_per_angle.9.html
That will give a polygon with a certain number of sides. (It doesn't do the quick retract, but will at least serve as a proof of concept)
7 years 11 months ago #121404 by Peter_Cassar
Thanks again Andy, I'll investigate the links.
Peter.
7 years 11 months ago #121406 by rodw
Replied by rodw on topic eccentric turning
Also, when you get V 2.8 installed to get the external offsets, there are a number of sims using the new features you can study. The one turning a hexagon is quite cool to watch even on the screen!
7 years 11 months ago #121408 by Peter_Cassar
Where do I find the link to V2.8? I can only see 2.7.14
Peter.
Time to create page: 0.302 seconds
