An open source Emco 120P lathe tool turret control
10 years 6 months ago #73267 by LutzTD
I am planning to reproduce your Toolerator 3000-C PCB for use on my emcoturn120. I have the files from the open source site listed above but I cant find a way to output the BOM from KiCAD. would you happen to have your BOM list? I imagine with some work I will be able to find all of the components but I thought you may already have a spreadsheet bom you could post. Any help would be appreciated.
10 years 6 months ago #73297 by tome
LutzTD wrote: Hi,
I will check with Dale to see if he has a list of parts. I was able to find these two hits for producing a BOM from KiCAD:
forum.kicad.info/t/kicad-bom-wizard-plug...tml-and-csv-bom/2142
rheingoldheavy.com/kicad-bom-management-...detailed-components/
-Tom
10 years 6 months ago - 10 years 6 months ago #73319 by LutzTD
hi Tom,
thanx for the reply. I was just being a little lazy, :) no problem. I did figure out the output from KiCAD and got the attached, but it was a little generic so I am guessing on some of it. I started going through and identifying the actual parts and where to buy them and thought since you are very organized you might have a spreadsheet already. Between this and the photos of the Toolerator 3000 PCBA on your picture site I think I can get it done. I will post it when I finish, if you could review it to make sure I did it right (Im an ME after all :))
Thanx
Last edit: 10 years 6 months ago by LutzTD. Reason: additional comment
10 years 6 months ago #73386 by LutzTD
here's a CAD Toolenator 3000 PCBA as I build the BoM. The DIN rail clip doesn'
t fit the holes in the PCB, still looking for the proper one, this one is from Hammond.
10 years 6 months ago #73401 by BigJohnT
Usually the DIN rail clips have an aluminum bar with standoffs like this
mesaus.com/index.php?route=product/produ...ath=70&product_id=88
JT
10 years 6 months ago #73455 by LutzTD
thanx JT, that looks to have the shorter spacing. I was considering adding another hole in the Hammond one or slotting the holes in the Toolenator 3000 PCB to make them work.
Time to create page: 0.087 seconds
