Pimping the mini-lathe
6 years 3 months ago #174205 by rodw
Replied by rodw on topic Pimping the mini-lathe
I wonder if it should be installed then?
Uninstalling it did not recover my 2 machines.
6 years 3 months ago #174206 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
I wandered off after trying that uninstall, leaving the thing running with only the terminal window open. After a half hour it nad not locked up yet. Then I started a latency check, and opened a couple of youtube windows, causeing it to freeze after about a minute.
6 years 3 months ago #174212 by PCW
Replied by PCW on topic Pimping the mini-lathe
I would disable EIST and Turbo mode.
The lockups may be Intel video related, you might try adding
intel_idle.max_cstate=1 to the kernel command line (with grub)
6 years 3 months ago #174213 by Mike_Eitel
Replied by Mike_Eitel on topic Pimping the mini-lathe
My feeling is that you should switch off nearly everithing on the first page.
For yor freezing have a look
www.tipro.net/shared_files/support/disab..._state_reporting.pdf
Disable C-State reporting with J1900 CPU - Tipro
6 years 3 months ago - 6 years 3 months ago #174228 by RotarySMP
Good call guys. I turned off EIST, turbo and C state reporting in Bios, and it has now been running a couple of Youtube channels and the latency test for about an hour without freezing up.
Would their still be an advatage to do intel_idle.max_cstate=1 to the kernel command line (with grub)? I don't knwohow to do that yet, so it'll take me a bit of searching to find out.
I really appreciate yor help here.
Mark
Last edit: 6 years 3 months ago by RotarySMP.
6 years 3 months ago #174245 by tommylight
Replied by tommylight on topic Pimping the mini-lathe
Mike_Eitel wrote: My feeling is that you should switch off nearly everithing on the first page.
To late to the party, was welding and cutting....
That was the correct answer from Mike.
Moderators: piasdom
Time to create page: 0.281 seconds
