Pimping the mini-lathe
5 years 9 months ago #196195 by rodw
Replied by rodw on topic Pimping the mini-lathe
Unless the bios has changed (and it may have) this PC worked OK for me.
You need to edit the bios to disable any of the C7 type wait states.
Too long ago for me to remember
The following user(s) said Thank You: RotarySMP, EMOFLY
5 years 9 months ago #196263 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
I basically turn off everything in the bios. All the options on the CPU, the audio, etc.
Mark
5 years 9 months ago #196287 by EMOFLY
Replied by EMOFLY on topic Pimping the mini-lathe
I turned off everything like you.
But when I choose the kernel with RT in the name at the grub customizer menu, PC is freeze after 1 minute.
Can you post here your uname -a
5 years 9 months ago #196317 by EMOFLY
Hi,everyone
I have update version of kernel, with this 4.16.12-rt5-kona-rt, and this is the result.
All night working,no freezing.
Is that results are, good for this PC.
Emil
5 years 9 months ago #196492 by andypugh
Replied by andypugh on topic Pimping the mini-lathe
Sorry, but that's rather poor latency (max jitter)
As an experiment, try running the LinuxCNC live image in "Live" mode (ie, leave your hard drive and current installer untouched) to see what that kernel gives you for latency.
You could also try the RTAI kernel.
5 years 9 months ago #196524 by rodw
andypugh wrote: Sorry, but that's rather poor latency (max jitter)
I think the latency test needs to be redone without the base thread. For a Mesa Ethernet card which is all this USFF PC can run, I think the servo thread latency is OK
Moderators: piasdom
Time to create page: 0.407 seconds
