- Thank you received: 5334
Pimping the mini-lathe
5 years 10 months ago #191070
Replied by PCW on topic Pimping the mini-lathe
I don't see anyway that the jog scale values are set
The default scale is likely 0 so if these are not
set, I would not expect any motion
That is I don't see
joint.N.jog-scale
axis.C.jog-scale
connected in your hal file
They may be connected in you main hal file
but are certainly something to add to your
halshow debug watch list
That is I don't see
joint.N.jog-scale
axis.C.jog-scale
- Thank you received: 4153
5 years 10 months ago #191071
Replied by rodw on topic Pimping the mini-lathe
You seem to be connecting to gmocappy pins. My guess that driving the dro but not the machine.
My complete config
I never have got ilowpass working nicely. get it wrong like I did and one click = 1 metre so be careful the first move!
My complete config
Warning: Spoiler!
# --- PENDANT SELECT JOG MODE (Yellow Button)---
net pendant-jog <= hm2_7i76e.0.7i76.0.0.input-30
net pendant-jog => halui.mode.teleop
# --- MPG JOG WHEELS FOR X AND Y AXIS ---
# ilowpass filter
setp ilowpass.0.scale 10
setp ilowpass.0.gain 0.01
# Setup Jog Pendant on each axis
setp axis.x.jog-vel-mode 0
setp axis.y.jog-vel-mode 0
setp axis.z.jog-vel-mode 0
# Scale Select
setp mux4.0.in0 0.0
setp mux4.0.in1 1.0
setp mux4.0.in2 0.01
setp mux4.0.in3 0.1
#Axis Select (0=off, 1=x, 2=z, 3=y, na, 5=6, 6=4, 7=5)
setp mux8.0.in0 0
setp mux8.0.in1 1
setp mux8.0.in2 2
setp mux8.0.in3 3
setp mux8.0.in4 4
setp mux8.0.in5 5
setp mux8.0.in6 6
setp mux8.0.in7 7
net mux8-sel0 <= hm2_7i76e.0.7i76.0.0.input-23
net mux8-sel1 <= hm2_7i76e.0.7i76.0.0.input-24
net mux8-sel2 <= hm2_7i76e.0.7i76.0.0.input-25
net mux8-sel0 => mux8.0.sel0
net mux8-sel1 => mux8.0.sel1
net mux8-sel2 => mux8.0.sel2
#setp conv-float-s32.0.clamp 0
net mux-float <= mux8.0.out
net mux-float => conv-float-s32.0.in
net mux-s32 <= conv-float-s32.0.out
net mux-s32 => select8.0.sel
net axis-select-x <= select8.0.out1
net axis-select-y <= select8.0.out3
net axis-select-z <= select8.0.out2
net axis-select-4 <= select8.0.out6
net axis-select-5 <= select8.0.out7
net axis-select-6 <= select8.0.out5
net axis-select-x => axis.x.jog-enable
net axis-select-y => axis.y.jog-enable
net axis-select-z => axis.z.jog-enable
# Encoder counts
net jog-counter <= hm2_7i76e.0.7i76.0.0.enc0.count
net jog-counter => ilowpass.0.in
net smooth-counter <= ilowpass.0.out
net jog-counter => axis.x.jog-counts
net jog-counter => axis.y.jog-counts
net jog-counter => axis.z.jog-counts
net mux4-sel1 <= hm2_7i76e.0.7i76.0.0.input-22
net mux4-sel0 <= hm2_7i76e.0.7i76.0.0.input-21
net mux4-sel1 => mux4.0.sel1
net mux4-sel0 => mux4.0.sel0
net jog-scale <= mux4.0.out
net jog-scale => axis.x.jog-scale
net jog-scale => axis.y.jog-scale
net jog-scale => axis.z.jog-scale
5 years 10 months ago #191072
Just an aside, my pendant has a yellow safety button that must be pressed to use the MPG dial. I use it to select the gmocappy jog tab otherwise noting will work.
- RotarySMP
- Thank you received: 595
5 years 10 months ago #191074
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Those last three lines:
net jog.inc1 select8.0.out1 => gmoccapy.jog.jog-inc-0
net jog.inc2 select8.0.out2 => gmoccapy.jog.jog-inc-1
net jog.inc3 select8.0.out3 => gmoccapy.jog.jog-inc-2
set the jog increments to continuous, 0.1mm and 0.01mm I defined in the Gmoccapy ini. This works. I flick that switch and the corresponding gmoccapy screen button becomes active. Also the on screen jog buttons follow this setting correctly.
I thought I had tried setting joint.[].jog-scale and axis.().jog-scale to 1 or other values to see if that did anything, but it makes sense if I am passing steps of 0, nothing happens. I'll try again setting them to 1 tomorrow.
Rod, I see you yellow jog activate button is net to halui.mode.teleop. I'll try netting my jog axis enable to that and see if it works.
Mark
Mark
5 years 10 months ago - 5 years 10 months ago #191075
joint.0.jog-scale
axis.X.jog-scale
joint.1.jog-scale
axis.Z.jog-scale
Are the pins that need to be set to 0.01 or 0.1
they set the jog increment per count
man motion
axis.X.jog-scale
joint.1.jog-scale
axis.Z.jog-scale
man motion
Last edit: 5 years 10 months ago by PCW.
- RotarySMP
5 years 10 months ago #191079
by RotarySMP
I guess I assumeed that connect to Norbert goccapy pins would do this and the gui buttons at the same time, guess I need to do them both.
Moderators: piasdom
Time to create page: 0.483 seconds
