Pimping the mini-lathe
6 years 2 weeks ago #185828
Sadly, I think it is
Replied by andypugh on topic Pimping the mini-lathe
RotarySMP wrote: Just playing around, what is the syntax to use natural constants like Pi or "e" in gcode?
Code:#<103>=[pi/e]
#103 = 1.155727349790922
- RotarySMP
- Thank you received: 595
6 years 2 weeks ago #185837
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Yep, at least I learned you can do named variables.
;Weird thread
;Why? Because a CNC lathe can!
;Tapered 3 start RH thread 23/57"OD x Pi TPcm, 11/7 Chi long, with a 23/19e taper angle.
;Z0 is end of stock.
#<_pi> = 3.14159
#<_e> = 2.71828
#<_chi>= 30.3
#<_starts> = 3
#<_OD> = [23/57*25.4]
#<_Z_LeadIn> = [#<_pi>*4]
#<_Pitch> = [#<_pi>]
#<_ThreadDepth> = [#<_pi> /3 ]
#<_ThreadLength> =-[#<_chi>*11/7]
#<_TaperAngle> = [23/19*#<_e>]
#<_NumThreadPasses> = ROUND[#<_ThreadDepth>/0.1]
#<_SmallDia> = [#<_OD> - [SIN[#<_TaperAngle>*2]] *[#<_Z_LeadIn> + ABS[ #<_ThreadLength>]]]
#<_DiaChange> = [#<_OD> - #<_SmallDia>]
#<_NumCuttingPasses> = ROUND[#<_DiaChange>]
#<_stockDia> = 20
#<_stockOff> = [#<_stockDia> - #<_OD> ]
#<_NumsizePasses> = ROUND[#<_stockOff>]
#<_feedrate> = 150
#<_Speed> = 1000
#1 = 1 ; Index start passes
#2 = 1 ; Index threading passes
#3 = 1 ; Index cutting passes
#4 = 1 ;Index resize
O110 sub ;Cut taper
O110 while [#3 LE #<_NumCuttingPasses>]
G0 Z[#<_Z_LeadIn>]
X[#<_SmallDia> + [[#<_NumCuttingPasses> - #3] * [#<_DiaChange> / #<_NumCuttingPasses> ]]]
G01 Z[#<_ThreadLength>] X[#<_OD> + [[#<_NumCuttingPasses> - #3] * [#<_DiaChange> / #<_NumCuttingPasses> ]]] F#<_Feedrate>
G0 X[#<_OD> + #<_DiaChange>]
#3 = [#3 +1]
O110 Endwhile
O110 endsub
O111 sub ; Cut Thread
O100 while [#1 LE #<_starts>]
O101 while [#2 LE#<_NumThreadPasses>]
G0 Z[#<_Z_LeadIn> + [[#1 - 1] * [#<_Pitch>/#<_starts>]]]
X[#<_SmallDia> - [[#2]*[#<_ThreadDepth> / #<_NumThreadPasses> ]]]
G33 Z[#<_ThreadLength>] X[#<_OD> - [[#2 - 1] * [#<_ThreadDepth>/ #<_NumThreadPasses> ]]] K#<_Pitch>
#2 = [#2 + 1]
O101 endwhile
M5
G4 P2
M3
G4 P2
#2 =1
#1 = [#1 +1]
#<_SmallDia> = [#<_SmallDia> - [SIN[#<_TaperAngle>]*[#1 -1] * [#<_Pitch>/#<_starts>]]]
O100 EndWhile
O111 endsub
O120 Sub ; resize stock
O121 while [ #4 LE #<_NumsizePasses>]
M3
G0 X [#<_stockDia> +1]
G0 Z1
G01 X [#<_stockDia> - [#<_stockOff> / #<_NumsizePasses> * #4] ] F #<_feedrate>
g01 Z [#<_ThreadLength>]
#4 = [#4+1]
O121 endwhile
O120 endsub
;Main
G18 G21 G40 G49 G54 G80 G94 G90 G7
F#<_Feedrate> S#<_Speed>
M3
G4 P2
O120 call
O110 call
M5
G4 P2
M3
O111 call
M9 M5
M2
- my1987toyota
- Thank you received: 449
6 years 2 weeks ago #186135
by my1987toyota
true.
I know it's still a little early but how is the computer working out for your mini lathe build ? would you recommend it?
Replied by my1987toyota on topic Pimping the mini-lathe
RotarySMP wrote: I have some fitted soft jaw copper shims like that for my four jaw, but didn't have any for the three jaw.
I am sure that the G0602 is significantly more rigid than the mini lathe.looks like I am going to be binge watching this whole series and taking notes for my upcoming G0602 build .
Mark
true.
- RotarySMP
6 years 2 weeks ago #186295
by RotarySMP
It was a pita to set up (but that was probably just personal incompetence). It boots pretty slowly. It runs fine with the Mesa 7i97, I have not had any stablity issues with it. Its internal WiFi widget was automatic configured by Mint, so that was nice benefit, as I could easily häng it on my WiFi network.
Mark
Mark
The following user(s) said Thank You: my1987toyota
- my1987toyota
6 years 2 weeks ago #186332
by my1987toyota
If you don't mind RotarySMP I have another question for you . How do you like the omron rotary encoder
would you recommend using it?
- RotarySMP
6 years 2 weeks ago #186344
by RotarySMP
It was easy to hook up and works flawlessly so far.
Moderators: piasdom
Time to create page: 0.144 seconds
