Pimping the mini-lathe
6 years 1 month ago - 6 years 1 month ago #182003 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
E30 is up. The first time I used tool offsets, including a crash due to my lack of understanding combined with carelessnes.
Mark
Last edit: 6 years 1 month ago by RotarySMP.
The following user(s) said Thank You: tommylight, StoneB
6 years 4 weeks ago - 6 years 4 weeks ago #184796 by RotarySMP
I just uploaded episode 31...
Mark
Last edit: 6 years 4 weeks ago by RotarySMP.
The following user(s) said Thank You: phillc54, tommylight
6 years 3 weeks ago #185692 by RotarySMP
Episode 32. This is to fix up a screw up I made.
Mark
6 years 3 weeks ago - 6 years 3 weeks ago #185708 by machinedude
Replied by machinedude on topic Pimping the mini-lathe
A set screw should work just fine on your pulley.
one other thing that works well for protecting the parts in the lathe is to cut some aluminum strips the width of the step on the outer part of you lathe jaw then bend them around the jaw so they hook on the jaw. this holds them in place so it's easy to load your parts. once you make them you can take them off and on when needed if you can remember where you put them :)
Last edit: 6 years 3 weeks ago by machinedude.
6 years 2 weeks ago #185711 by my1987toyota
Replied by my1987toyota on topic Pimping the mini-lathe
looks like I am going to be binge watching this whole series and taking notes for my upcoming G0602 build .
6 years 2 weeks ago #185822 by RotarySMP
I have some fitted soft jaw copper shims like that for my four jaw, but didn't have any for the three jaw.
I am sure that the G0602 is significantly more rigid than the mini lathe.
Mark
The following user(s) said Thank You: my1987toyota
Moderators: piasdom
Time to create page: 0.154 seconds
