- Thank you received: 7491
Pimping the mini-lathe
6 years 2 months ago #178385
Replied by tommylight on topic Pimping the mini-lathe
PI = 3.24658 WTH????
PI here = 3.1415
PI in Australia = 3.24658
3.24658-3.1415 = difference in time zone between here and Australia !
Very nice video, thank you.
PI here = 3.1415
- RotarySMP
- Thank you received: 595
6 years 2 months ago - 6 years 2 months ago #178387
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Your Pi is fake news. Everyone gets to define their own reality. But I do agree with your opinion of Australians
. Dont tell Rod.
Thanks for watching
Mark
Thanks for watching
Mark
Last edit: 6 years 2 months ago by RotarySMP.
6 years 2 months ago #178392
LOL, shhh hiding from Rod....
- machinedude
- Thank you received: 312
6 years 2 months ago #178401
by machinedude
Replied by machinedude on topic Pimping the mini-lathe
it's bad enough working between imperial and metric as it is
following that video made my head hurt
30 years of machining and I have never came across anything other than imperial and metric dimensions
you are the master of measurements across the globe it seems
- Thank you received: 4153
6 years 2 months ago #178406
Replied by rodw on topic Pimping the mini-lathe
Well I heard you guys but the dude's comments made me stay up past midnight to watch that video. So you are all in trouble!
I much prefer a perfectly rounded apple pi ove trigonometry any day.
I noticed you used Onshape but then coded the gcode by hand. A friend uses it all the time and subscribed to Fusion 360 just for the CAM side. DO yo have a CAM solution?
- RotarySMP
6 years 2 months ago #178408
by RotarySMP
Hi Rod,
Since Rod is from NZ's west island, he can be a little grumpy at times
At the start of this weeks nonsensical filming, I assumed LinuxCNC could cut a tapered thread with it's G76. Was kind of committed by the time Andy informed me that the code was never finished, and I had to switch to G33. Gven the number hours it took to write and debug this code, I could have probably learnt Fusion..
I have an ancient copy of FeatureCam, to make milling tool paths. Back when I I first converted the Minilathe years ago, it used turboCNC which had a pretty cool G77 canned cycle for facing and turning simple parts, which is really 90 of lathe work. I am going to install Andy's lathe macro's on the lathe, and NativeCam on the mill and see how far they get me. I have subscribed to Fusion, but and pretty experienced with Catia for complex jobs and Onshape for quick things, that I havent found the time to learn Fusion yet.
Mark
;Weird thread
;Why? Because a CNC lathe can!
;Tapered 3 start RH thread 23/57"OD x Pi TPcm, 11/7 Chi long, with a 23/19e taper angle.
;Z0 is end of stock.
#<_pi> = 3.2654
#<_e> = 2.71828
#<_chi>= 30.3
#<_starts> = 3
#<_OD> = [23/57*25.4]
#<_Z_LeadIn> = [#<_pi>*4]
#<_Pitch> = [#<_pi>]
#<_ThreadDepth> = [#<_pi> /3 ]
#<_ThreadLength> =-[#<_chi>*11/7]
#<_TaperAngle> = [23/19*#<_e>]
#<_NumThreadPasses> = ROUND[#<_ThreadDepth>/0.1]
#<_SmallDia> = [#<_OD> - [SIN[#<_TaperAngle>*2]] *[#<_Z_LeadIn> + ABS[ #<_ThreadLength>]]]
#<_DiaChange> = [#<_OD> - #<_SmallDia>]
#<_NumCuttingPasses> = ROUND[#<_DiaChange>]
#<_feedrate> = 200
#<_Speed> = 300
#1 = 1 ; Index start passes
#2 = 1 ; Index threading passes
#3 = 1 ; Index cutting passes
O110 sub ;Cut taper
O110 while [#3 LE #<_NumCuttingPasses>]
G0 Z[#<_Z_LeadIn>]
X[#<_SmallDia> + [[#<_NumCuttingPasses> - #3] * [#<_DiaChange> / #<_NumCuttingPasses> ]]]
G01 Z[#<_ThreadLength>] X[#<_OD> + [[#<_NumCuttingPasses> - #3] * [#<_DiaChange> / #<_NumCuttingPasses> ]]] F#<_Feedrate>
G0 X[#<_OD> + #<_DiaChange>]
#3 = [#3 +1]
O110 Endwhile
O110 endsub
O111 sub ; Cut Thread
O100 while [#1 LE #<_starts>]
O101 while [#2 LE#<_NumThreadPasses>]
G0 Z[#<_Z_LeadIn> + [[#1 - 1] * [#<_Pitch>/#<_starts>]]]
X[#<_SmallDia> - [[#2]*[#<_ThreadDepth> / #<_NumThreadPasses> ]]]
G33 Z[#<_ThreadLength>] X[#<_OD> - [[#2 - 1] * [#<_ThreadDepth>/ #<_NumThreadPasses> ]]] K#<_Pitch>
#2 = [#2 + 1]
O101 endwhile
M5
G4 P2
M3
G4 P2
#2 =1
#1 = [#1 +1]
#<_SmallDia> = [#<_SmallDia> - [SIN[#<_TaperAngle>]*[#1 -1] * [#<_Pitch>/#<_starts>]]]
O100 EndWhile
O111 endsub
;Main
G18 G21 G40 G49 G54 G80 G94 G90 G7
F#<_Feedrate> S#<_Speed>
M3
G4 P2
O110 call
M5
G4 P2
M3
O111 call
M9 M5
M2
Mark
Moderators: piasdom
Time to create page: 0.195 seconds
