Pimping the mini-lathe
6 years 2 months ago - 6 years 2 months ago #177208 by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
I used a concrete vibration motor to vibrate the parts I made. I guess you could clean out the concrete mixer with a few shovels full of gravel and gallon of acetone after the last mix. Any remaining epoxy would be soon worn out once you used it for concrete again.
Last edit: 6 years 2 months ago by RotarySMP.
6 years 2 months ago #177231 by Mike_Eitel
Replied by Mike_Eitel on topic Pimping the mini-lathe
For my epoxy stuff (making diving rebreathers) i sucessfully use normal cheep candel wax. If geting out is a problem, heatgun is yourbest friend.
Mike
6 years 2 months ago - 6 years 2 months ago #177507 by RotarySMP
I cleaned up my wiring diagrams (attached). Pretty simple so far.
Mark
6 years 2 months ago #177591 by RotarySMP
Just playing around, what is the syntax to use natural constants like Pi or "e" in gcode?
#<103>=[pi/e]
Mark
6 years 2 months ago #177598 by RotarySMP
Given that my lathe only uses a fraction of the 7i96's capacity (2 Stepgen, 1 ENC and 1 Pwmgen) at present, would it be possible to add a further encoder through mesaflash to read a jog wheel? I looked through the bit files, and see there is one that looks like it converts to six ENC (7i96_6enc_d.bit). What would I need to do to make a 1pwmgen+ 1 addition ENC bitfile?
Actually given that jogwheels are only 100 PPR, and the normal input pins are read at 1kHz, I can't hand jog at 10 RPS anyway, so there is probably no disadvantage of puttnig the jog wheel onto general I/O except that they need a few pins.
Bonus question, would it be possible to reconfigure both the two unused Stepgens to ENC? With two stepgens, 1 pwmgen, and 3 Enc (the existing one plus two more), I could add linear encoders to the two axis, and run the jog wheel off I/O. That would be awsome for a lathe.
Mark
6 years 2 months ago #177601 by tommylight
Replied by tommylight on topic Pimping the mini-lathe
RotarySMP wrote: Bonus question, would it be possible to reconfigure both the two unused Stepgens to ENC?
I do not think so
stepgens = outputs
enc = inputs
but you do have a 26 pin header that you can use for anything and they are very fast, so there is room for some 8 more encoders there.
Moderators: piasdom
Time to create page: 1.311 seconds
