- Thank you received: 4153
Pimping the mini-lathe
5 years 10 months ago #191085
You need to forget about the gmocappy pins. I don't use them and it works.
You do need to be on the jogging tab or it won't work. Thats what I use my yellow button for. TO always select that tab.
Replied by rodw on topic Pimping the mini-lathe
RotarySMP wrote: I guess I assumeed that connect to Norbert goccapy pins would do this and the gui buttons at the same time, guess I need to do them both.
- RotarySMP
- Thank you received: 595
5 years 10 months ago #191224
by RotarySMP
Replied by RotarySMP on topic Pimping the mini-lathe
Thanks Rod, that was the key.
This weeks video is....well, see for yourself
Mark
Mark
5 years 10 months ago #191246
Dunno about the Guru bit. But did you need to be on the jogging tab? Was that the key?
- RotarySMP
5 years 10 months ago #191250
by RotarySMP
Like you said, forget netting with the GUI buttons. Although I then did that as well in parallel, just to see if you can have the screen buttons follow the INCR switch. But that is probably pointless.
- RotarySMP
5 years 10 months ago #191253
by RotarySMP
- Thank you received: 7491
5 years 10 months ago #191269
Replied by tommylight on topic Pimping the mini-lathe
LOL
and btw, LinuxCNC has a built in halscope. It's been quite a while since i have turned on my old scopes.
Moderators: piasdom
Time to create page: 0.171 seconds
