Huyndai hit 15s retrofit
3 years 10 months ago #260078 by tommylight
Replied by tommylight on topic Huyndai hit 15s retrofit
This is the first time i see 3x220v input with 3x400v output, it is usually the other way round.
3 years 10 months ago #260082 by Mr.
Replied by Mr. on topic Huyndai hit 15s retrofit
I agree, ill do some more investgating today, i know the 400v goes to the spindle motor from the contactor but im not sure where the other 220 3ph goes. Ill poke aroubd today
3 years 10 months ago #260085 by Henk
Replied by Henk on topic Huyndai hit 15s retrofit
Check out the Siemens power supply module. It provides the DC bus power to the Siemens 611 drive modules. Post the model number if you can
The power supply is a clever one. Sensitive to phase sequence as well as supply voltage. It is not just a rectifier with caps, it is actually an  active igbt rectifier with regenerating capability.
This means that it can consume energy from the DC bus during spindle deceleration and push it back into the supply, making it much more efficient.
​​​​​​THis also causes problems for diesel generators as they are not designed to be driven by its load and they normally cut out or trip.
The following user(s) said Thank You: Mr.
3 years 10 months ago #260090 by Mr.
I will take a bunch of pics today, the gen im picking up was a natural gas/ propane gen that im going to convert to gasoline. Intresting about the power supply i was wondering why i didnt see a regen on it like the haas's i run
3 years 10 months ago - 3 years 10 months ago #260134 by Mr.
Some more pics
This is what there calling a reactor
Last edit: 3 years 10 months ago by Mr..
3 years 10 months ago - 3 years 10 months ago #260135 by Mr.
Line in from transformer etc
Time to create page: 0.065 seconds
