Huyndai hit 15s retrofit
3 years 10 months ago #260136 by Mr.
Replied by Mr. on topic Huyndai hit 15s retrofit
Drives
3 years 10 months ago #260148 by Henk
Replied by Henk on topic Huyndai hit 15s retrofit
Hi
The E/R module (F/B module) is the power supply. It requires 400 VAC 3phase. There is selector switches for 415V and 480V, but 400 is the minimum. It is a regenerative power supply.
search your part numbers on the siemens site for the manuals: mall.industry.siemens.com/
Each axis drive and spindle drive is fitted with a "control board" You need the "Universal" one, it is the only one that supports analog control.
Henk
The following user(s) said Thank You: Mr.
3 years 10 months ago - 3 years 10 months ago #260159 by Mr.
Any idea if theres a visual differance between the 2?
Last edit: 3 years 10 months ago by Mr..
3 years 10 months ago #260194 by Mr.
Got some more pics , 611 part number come back to universal so i think were good there.
3 years 10 months ago #260197 by tommylight
Replied by tommylight on topic Huyndai hit 15s retrofit
Wires:
P24 = +24V from other source used for signaling
+24V = what it says, not the same as above, should not be wired together or mixed.
SRDY = servo ready
XFLT = X fault
0VG2 = 0V ground, goes with +24V, not with P24
ZFLT = Z fault
no more :(
3 years 10 months ago - 3 years 10 months ago #260216 by Henk
It does seem that you have the analog version. in this pic below, terminals 56 and 14 are the analog +-10v command.
Im having trouble finding the siemens manual for your specific part numbers
***edit....pasting the pic doesnt seem to work
Last edit: 3 years 10 months ago by Henk.
Time to create page: 0.080 seconds
