Troubles to get started with SD240 Retrofit
- Thank you received: 5314
04 Jul 2025 21:12 #331270
Replied by PCW on topic Troubles to get started with SD240 Retrofit
Sounds like the jogging setup in the hal file is not quite right
can you post your hal file?
- ziggi
- Thank you received: 4
05 Jul 2025 08:26 - 05 Jul 2025 08:29 #331305
by ziggi
Replied by ziggi on topic Troubles to get started with SD240 Retrofit
Thank you for the reply, attached you find the current HAL and INI files
Sigi
Sigi
Last edit: 05 Jul 2025 08:29 by ziggi.
05 Jul 2025 14:47 #331319
Looks basically ok
Maybe the machine does not think its homed
You should be able to jog without homing by adding
the joint jog pins:
# ---Handrad-Signale zu Mesa Encoder - shared MPG---
net axis-selected-count <= hm2_7i80.0.encoder.03.count
# ---mpg signals---
# for axis x MPG
setp axis.x.jog-vel-mode 0
net selected-jog-incr => axis.x.jog-scale joint.0.jog-scale
net axis-select-x => axis.x.jog-enable joint.0.jog-enable
net axis-selected-count => axis.x.jog-counts joint.0.jog-counts
# for axis z MPG
setp axis.z.jog-vel-mode 0
net selected-jog-incr => axis.z.jog-scale joint.1.jog-scale
net axis-select-z => axis.z.jog-enable joint.1.jog-enable
net axis-selected-count => axis.z.jog-counts joint.1.jog-counts
sets selected-jog-incr 1.000000
the joint jog pins:
# ---mpg signals---
# for axis x MPG
# for axis z MPG
- ziggi
05 Jul 2025 16:12 #331325
by ziggi
- ziggi
05 Jul 2025 17:01 #331331
by ziggi
No, sorry- doesn´t do it. No jogging the selected axis possilble.
05 Jul 2025 17:32 - 05 Jul 2025 17:33 #331334
Does normal motion work?
When attempting jogging, what does:
halcmd show pin | grep jog
(typed in a terminal) report?
Last edit: 05 Jul 2025 17:33 by PCW.
- ziggi
05 Jul 2025 20:19 - 05 Jul 2025 21:27 #331341
by ziggi
Yes, normal jogging with the + - buttons works perfectly.
the command brings up the following when I write the command into the terminal and press ENTER while turning the handwheel.
Last edit: 05 Jul 2025 21:27 by ziggi.
06 Jul 2025 03:00 #331364
Note that no axis has jog enabled, you probably need to trace these back
to halui or wherever they are supposed to come from...
29 s32 IN 38852 axis.x.jog-counts <== axis-selected-count
29 bit IN FALSE axis.x.jog-enable <== axis-select-x
29 float IN 1 axis.x.jog-scale <== selected-jog-incr
29 bit IN FALSE axis.x.jog-vel-mode
29 bit OUT FALSE axis.x.kb-jog-active
29 bit OUT FALSE axis.x.wheel-jog-active
29 float IN 1 axis.y.jog-accel-fraction
29 s32 IN 0 axis.y.jog-counts
29 bit IN FALSE axis.y.jog-enable
29 float IN 0 axis.y.jog-scale
29 bit IN FALSE axis.y.jog-vel-mode
29 bit OUT FALSE axis.y.kb-jog-active
29 bit OUT FALSE axis.y.wheel-jog-active
29 float IN 1 axis.z.jog-accel-fraction
29 s32 IN 38852 axis.z.jog-counts <== axis-selected-count
29 bit IN FALSE axis.z.jog-enable <== axis-select-z
29 float IN 1 axis.z.jog-scale <== selected-jog-incr
29 bit IN FALSE axis.z.jog-vel-mode
29 bit OUT FALSE axis.z.kb-jog-active
- ziggi
06 Jul 2025 09:55 #331381
by ziggi
Thanks for the hint.
I will try to find out how these pins can be set TRUE when starting Linuxcnc.
Ok, the y-axis I do not need for the lathe, but X and Z. So some homework to do.
Thanks PCW
Sigi
Thanks PCW
Sigi
- ziggi
10 Jul 2025 10:01 - 10 Jul 2025 14:10 #331623
by ziggi
I think I probably detected the source of these weird settings disabling jog. Guess it can just be the Config file. Nowhere else I can find a similar demonination of the pins etc.
I have to check this, but I started with a config file created by PC-Config and without MPG included.
Then I had PC-Config create a new one with a different name and copied the MPG related lines of the newly created .hal file to my existing .hal file.
But the config file is still the initial one (without MPG) and therefore jogging is disabled.
I will try this weekend to create a new config file with PC-Config, include the MPG and all data I know mean while. Hope to get it working this way.
Sigi
Sigi
Last edit: 10 Jul 2025 14:10 by ziggi.
Moderators: piasdom
Time to create page: 2.752 seconds
