Troubles to get started with SD240 Retrofit
  • ziggi
  • ziggi's Avatar Topic Author
  • Senior Member
  • Senior Member
13 Jul 2025 17:09 #331772 by ziggi
No unfortunately a new Config with a MPG already included did not do the trick.
Manual jogging the X and Z axes works, continuos and inkremental but not with the encoder I intend to use as MPG.
I once again ran the suggested command "halcmd show pin | grep jog" - report attached.
Did not imagine it would be this challenging to get a MPG connected...
Sigi
File Name: SD240_V4.ini
File Size:3 KB
File Name: SD240_V4.hal
File Size:10 KB
File Name: halcmnd_jog.txt
File Size:7 KB
13 Jul 2025 21:23 #331785 by PCW
Again, the jog enables are false so the jog counts are ignored.
The jog enables are false because they are not connected to any
source (no hal "out" pin)
note that halui.axis.x.select and halui.axis.z.select pins are hal "in"
pins so can not enable anything.
What do you do to select an axis for jogging?
This part seems to be missing
That is, these need an additional connection
from whatever selects an axis for jogging:
net axis-select-x halui.axis.x.select
net axis-select-z halui.axis.z.select
The following user(s) said Thank You: ziggi
13 Jul 2025 23:53 #331797 by Benb
Following is a hal netlisting for the MPG part of your question:
# Set jog-vel-mode to false (joint will move exactly jog-scale units for each count)
setp joint.0.jog-vel-mode 0
setp joint.2.jog-vel-mode 0
setp axis.x.jog-vel-mode 0
setp axis.z.jog-vel-mode 0
# Set jog scale
setp mpg-scale 1.0
net  mpg-scale joint.0.jog-scale axis.x.jog-scale
net  mpg-scale joint.2.jog-scale axis.z.jog-scale
# Joint selection (enable only one at a time)
net mpg-select-x joint.0.jog-enable axis.x.jog-enable <= hm2_7ixx.your selector switch input
net mpg-select-z joint.2.jog-enable axis.z.jog-enable <= hm2_7ixx.your selector switch input
# Connect encoder counts to all joints (only enabled one will move)
net mpg-counts  hm2_7ixx.your mpg encoder address
net mpg=counts  joint.0.jog-counts  axis.x.jog-counts
net mpg-counts  joint.2.jog-counts  axis.z.jog-counts
  • ziggi
  • Senior Member
  • Senior Member
14 Jul 2025 05:32 - 14 Jul 2025 07:27 #331805 by ziggi
Oh, damned... Thank you for the brief explanation.
The root of all the trouble seems I understood this totally wrong.
I thought "selected axis" and also the "increment" was taken from the AXIS screen- both can be chosen there
Sorry for my sillyness. Now I understood that I need to connect the MPG in the HAL via in/outputs.
Thank you both of you
​​​​​​​Sigi
Last edit: 14 Jul 2025 07:27 by ziggi.
  • ziggi
  • Senior Member
  • Senior Member
16 Jul 2025 10:41 - 16 Jul 2025 10:42 #331891 by ziggi
In this thread it was asked how to link parport signals to axis: forum.linuxcnc.org/21-axis/31791-how-to-...l-signal-to-axis-jog
and an example was given.
Wouldn´t it be possible to link the AXIS screen status to the MPG signal  too? - so the other way round..
In other words use the selection chosen in AXIS of the axis and increment and link them to the jog mode, so that except the encoder no external elements for the axes and increment selection are necessary?
Might not make sense for a mill where you want a kind of remote control, but for a small lathe it would be convinient...
Last edit: 16 Jul 2025 10:42 by ziggi.
  • ziggi
  • Senior Member
  • Senior Member
25 Jul 2025 05:30 #332294 by ziggi
So I found the AXIS Gui document and if I apply the pins described there to your MPG code, it should be about this
setp joint.1.jog-vel-mode 0
# Set jog scale
setp mpg-scale 1.0
net  mpg-scale joint.0.jog-scale axis.x.jog-scale <= halui.axis.selected.increment
net  mpg-scale joint.1.jog-scale axis.z.jog-scale <= halui.axis.selected.increment
net mpg-select-x joint.0.jog-enable axis.x.jog-enable <= halui.axis.selected.0
net mpg-select-z joint.1.jog-enable axis.z.jog-enable <= halui.axis.selected.1
net mpg-counts  <=  hm2_7i80.0.encoder.03.count
net mpg-counts  joint.1.jog-counts  axis.z.jog-counts
Is this how it could work to use the AXIS-GUI pins instead of an axis and a increment selctor switches?
Sigi
  • ziggi
  • Senior Member
  • Senior Member
30 Aug 2025 21:28 - 31 Aug 2025 08:56 #334157 by ziggi
Sorry to bother you again guys. With the help of some people I have the axes and the spindle going now.
My current issue is the homing of the axes. They do not move to search for the home- switches, but just home "in place" so just where they stand. Obviously the axes pretend to "be homed" then, because softlimits are active. Signal joint.1.homed swaps immediately to yellow
If I unhome all axes I can move them where I want by jogging them- otherwise the + way is limited as it should be to 5/10mm +.
The hm2_7i80.0.gpio.026.in reacts in HAL-show on pushing the home switch manually and also the signal  "z-home-sw" swaps from red to yellow together with hm2_7i80.0.gpio.026.in.
The signal "z-is-homed" stays red .... if this is of any importance.
It is just that the search for the HOME signal does not take place. When trying to home an axis the axis motor is activated, stops immediately (does not move the axis) and sets the DRO value to 0.0
Any help appreciated
Thank you
Sigi
Last edit: 31 Aug 2025 08:56 by ziggi.
31 Aug 2025 16:59 #334190 by andypugh
Replied by andypugh on topic Troubles to get started with SD240 Retrofit
Does it help if I say that I am as puzzled as you? Those config files look like they should do homing.
Is there any chance you are not running the config you think you are?
It might be worth halscoping the home switch signals, perhaps there is noise on those that looks like valid home switch-on home-switch-off ? (very unlikely, though)
  • ziggi
  • Senior Member
  • Senior Member
31 Aug 2025 20:42 - 31 Aug 2025 20:45 #334200 by ziggi
No, no real help - but we found the error:
Wrong is the term VELOCITY - needs to be VEL thats all, then it works
so
Wrong:
HOME_SEARCH_VELOCITY = 10
HOME_LATCH_VELOCITY = 0.5
HOME_FINAL_VELOCITY = 1.0
Correct:
HOME_SEARCH_VEL = 10
HOME_LATCH_VEL = 0.5
HOME_FINAL_VEL = 1.0
Thats all, then it works
Sigi
Last edit: 31 Aug 2025 20:45 by ziggi.
  • ziggi
  • Senior Member
  • Senior Member
04 Sep 2025 07:23 #334389 by ziggi
Still struggeling a bit with the homing sequence.
In addition to the home switches I would like to use the encoder index to home. But the index is not found while homing.
So if I write "HOME_USE_INDEX = YES" in the INI, then the homing sequence does not end, even after 4 or 5 motor revolutions the index is not found. The index signal itsself is present- can see it in the oszy, it is also wired to the 7i80, so I assume it is not linked in the HAL correctly.
I hope someone can help me with this issue.
Sigi.
Moderators: piasdom
Time to create page: 0.129 seconds
