Considering a Full Rewire on a Working Schaublin 125 CNC
8 months 1 week ago #343483 by RotarySMP
Try a HAL with just this header in it... this works on my set of Mesa cards. You will probably need to change the IP address.
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=5 num_pwmgens=0 num_stepgens=0 sserial_port_0=0000000"
setp   hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
loadrt debounce cfg=3
loadrt matrix_kb config=8x8
addf hm2_7i92.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf hm2_7i92.0.write         servo-thread
setp hm2_7i92.0.dpll.01.timer-us -50
addf debounce.0               servo-thread
setp debounce.0.delay         5
addf matrix_kb.0              servo-thread
8 months 6 days ago #343544 by Dudelbert
@Rotary: I tried the minimal HAL you provided. I had to change the number of encoders from 5 to 4, but then it starts up fine as well. However, it does not change the Smart Serial problem—only channel 4 detects any cards.
The one 7i84 that was detected but gave undervoltage errors now works flawlessly. I did not change anything, so I am not sure why it did not work two days ago, but I will take the small win.
I also made some images of the wiring. I am not sure how clear they are. All the yellow cables are 24V, the red ones are 5V, and the black ones are GND.
8 months 5 days ago #343615 by RotarySMP
Is it possible that you have ended up with the wrong firmware flashed? I looked back and the last one I saw you mention was 7i92 plus 2x 7i85. Sounds okay, but maybe Peter can confirm that?
8 months 5 days ago #343618 by Dudelbert
I rechecked it multiple times myself. According to --readhmid, it should be fine. In the end,
I gave up and purchased a 7i97T. That should solve all the current problems and all it cost is money ;-)
That is the card I use in my mill. It has one Smart Serial port, and I will need two (for the 7i73 and one 7i85). I plan to build this small board from Talla83 ( github.com/talla83/RS422-SmartSerial-Adapter
), but for starting out, the I/O on the 7i97T itself should be sufficient to get most of the machine running.
8 months 5 days ago - 8 months 5 days ago #343624 by RotarySMP
Oh, I already ordered some of those board from JCLPCB years ago. I can send you a couple.
Last edit: 8 months 5 days ago by RotarySMP.
The following user(s) said Thank You: Dudelbert
8 months 5 days ago #343625 by Dudelbert
Thank you for the offer, but I already ordered them, and I suspect that postage for you would probably be more than the €4 for five pieces delivered from the other side of the planet. I still don’t understand how these prices are possible.
