Mesa 5i25 with plain G540, no 7i77
- Thank you received: 5188
25 Jan 2013 11:54 #29121
Replied by PCW on topic Mesa 5i25 with plain G540, no 7i77
sorry my typo, can you edit the 5i25-g540.ini file and change numpwmgens to num_pwmgens ?
- blacksmith99
- Thank you received: 4
26 Jan 2013 00:55 #29143
by blacksmith99
Replied by blacksmith99 on topic Mesa 5i25 with plain G540, no 7i77
No need to apologize, you have been very helpful.
Yes, I can do that. I'll try it tonight and report back.
Thanks!
Matt
Thanks!
Matt
- blacksmith99
26 Jan 2013 09:31 #29149
by blacksmith99
Two more typos:
setp hm2_[HOSTMOT2](BOARD).0.stepgen.04.control_type 1
Should be:
setp hm2_[HOSTMOT2](BOARD).0.stepgen.04.control-type 1
Also I think the part in bold is wrong, should it be a number? I tried 1 (one) but that didn't work.
net hm2_[HOSTMOT2](BOARD).0.stepgen.04.enable emcmot.00.enable
It did bring up LinuxCNC with no errors when I comment out that line. If that is for the charge pump I can turn off the charge pump input on the G540 and see what happens.
Getting closer!
I tried to upload the latest hal file but I can't get the attachment to upload. Nothing happened when I hit the "Open" button.
Thanks!
Matt
Should be:
Getting closer!
Thanks!
Matt
- blacksmith99
26 Jan 2013 09:37 #29150
by blacksmith99
Ok good news!
All of the axis move, I need to go in and invert the Z axis since I'm using a pulley on the Z and the motor is upside down.
I also need to set the scaling to the correct number of steps.
All that's left is the charge pump assuming everything else goes Ok.
How do I get the corrected hal file up on the forum?
Thank you!
Regards,
Matt
Thank you!
Regards,
Matt
26 Jan 2013 11:44 #29152
That line should probably be something like:
net charge-pump-enable hm2_[HOSTMOT2](BOARD).0.stepgen.04.enable emcmot.00.enable
I think you need to either rename it to end in .txt or zip it
- BigJohnT
- Thank you received: 1175
26 Jan 2013 21:29 #29160
by BigJohnT
The forum accepts patch,c,zip,txt,doc,gz,tgz,ngc,hal,ini,comp,dxf,clp,xml,pdf,stepconf,h,ui,glade extensions so you just have to add the hal file to your message.
Replied by BigJohnT on topic Mesa 5i25 with plain G540, no 7i77
- blacksmith99
27 Jan 2013 05:32 #29173
by blacksmith99
Does it want a pin number?
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
hm2-g540-stepper.hal:186: Pin 'emcmot.00.enable' does not exist
2102
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Thanks,
Matt
2102
Thanks,
Matt
27 Jan 2013 06:21 #29174
Sorry forgot emcmot.00.enable was a signal
net emcmot.00.enable hm2_[HOSTMOT2](BOARD).0.stepgen.04.enable
should be correct
should be correct
The following user(s) said Thank You: blacksmith99
- blacksmith99
27 Jan 2013 06:34 #29175
by blacksmith99
Yay! That did it.
Thank you for hanging in there with me.
Now, if I can figure out how to upload the hal and Ini file it might help someone else.
Regards,
Matt
Regards,
Matt
- blacksmith99
27 Jan 2013 07:40 - 27 Jan 2013 07:41 #29176
by blacksmith99
Here are the hal and ini files that are working for me.
Machine
Shopfox m1111 mill, CNC Fusion Deluxe Ballscrew kit with a 14 tooth timing belt pulley on the Z axis motor and an 18 tooth pulley on the Z axis ball screw.
G540 connected to a Mesa 5i25 with operating charge pump.
Hope this helps someone.
My thanks to PCW and BigJohnT for helping me.
The machine does seem to be a little smoother, however, right now I'm keeping the axis peeds down as you can see in the ini file.
The scale values were calculated by moving the axis exactly one inch on a dial indicator and adjusted until the travels were correct.
Note the scale value for the Z axis (Axis 2 in the ini) needs to have have a minus value to move the z axis in the right direction.
Thanks again for the help.
Regards,
Matt
Machine
Regards,
Matt
Last edit: 27 Jan 2013 07:41 by blacksmith99.
The following user(s) said Thank You: dbotos
Time to create page: 0.092 seconds
