Mesa 5i25 with plain G540, no 7i77
- Thank you received: 2157
27 Jan 2013 11:27 #29179
Replied by cmorley on topic Mesa 5i25 with plain G540, no 7i77
Well I fixed the Peter's experimental XML for PNcconf,
( Peter, there were a couple things just plain wrong eg secondaryfunction was showing primary functions and there are a lot of little spelling difference)
I just can't upload it right now for some reason-so someone can test.
One would still need to add some commands in a custom HAL file to set up the charge pump.
As that requires some changes in PNCconf to do automatically - and that has it's own problems....
I'll start a thread on that.
Chris M
Chris M
- blacksmith99
- Thank you received: 4
27 Jan 2013 13:07 #29181
by blacksmith99
Replied by blacksmith99 on topic Mesa 5i25 with plain G540, no 7i77
Chris,
I'll give a try once you get it uploaded.
Pncconf looks like a good tool. It would certainly help to make sense of things.
The fact that the Mesa 5i25 can have a lot of it's pins as either inputs or outputs make it difficult from a beginners stand point.
The Mesa seems less noisy driving the steppers. I saw speeds past 125 ipm which is fast for me right now. Kinda made me jump until I slowed things down a bit.
I'm still a little nervous and driving slow.
Thanks!
Matt
Thanks!
Matt
- pws
23 Apr 2013 04:09 #33025
by pws
Replied by pws on topic Mesa 5i25 with plain G540, no 7i77
Hello!
I realize this thread is over a year old, but it has been a tremendous help to me getting acclimated with using a Mesa 6i25/G540 combination in LinuxCNC - and I am new to it ALL!
I originally started to put this project together with an old PC with a Parallel port and using just what was available (stepconf), I was able to get all 4 steppers moving - then assembled the steppers/ballscrews on to a Large table for my Grizz X2 and things work GREAT. The PC was TOO old, though - gigantic jitter for one thing - so I decided to build a new system with modern components! That done, with the 6i25 and LinuxCNC installed, I embarked on creating the INI and HAL files using my old system ones as examples and the ones in THIS thread as "building blocks".
I suspect there is more information somewhere that I haven't found that will help me over the issues I am having constructing these files.
The main question I have at this point regards the PIN definitions. In my original HAL file, I have the following:
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
setp parport.0.pin-03-out-invert 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net astep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net adir => parport.0.pin-09-out
net spindle-cw => parport.0.pin-14-out
net spindle-pwm => parport.0.pin-16-out
net xenable => parport.0.pin-17-out
net both-home-x <= parport.0.pin-10-in
net both-home-y <= parport.0.pin-11-in
net both-home-z <= parport.0.pin-12-in
net both-home-a <= parport.0.pin-13-in
net probe-in <= parport.0.pin-15-in
Yet in the HAL file that is supplied in this thread, there is NO such PIN definition section. Do you NOT need to define these PINs with the 6i25/G540 combination?
Perhaps someone could point me to some documentation that will clear this fog for me and I can be on my way!
Thanks for your time!
Paul
Paul
- Thank you received: 4966
23 Apr 2013 05:54 #33029
Replied by andypugh on topic Mesa 5i25 with plain G540, no 7i77
Yes, exactly that. The function of each pin is defined by the firmware. The stepgens run on the FPGA, and connect directly to pins on the D-sub, not looping back through HAL at all.Yet in the HAL file that is supplied in this thread, there is NO such PIN definition section. Do you NOT need to define these PINs with the 6i25/G540 combination?
- pws
23 Apr 2013 06:52 #33032
by pws
Hi Andy,
Thanks for the response!
Can you tell me where I can find material that references all that?
I have the feeling that I also need to load a driver or something before this will all work with the LinuxCNC Distro. Anything that gives good simple preliminary setup guidance around? I have the ones from here, but everything I have seen talks around what my config needs!
Appreciate the help.
Paul
Paul
- Thank you received: 5205
23 Apr 2013 06:57 - 23 Apr 2013 06:58 #33033
Replied by PCW on topic Mesa 5i25 with plain G540, no 7i77
Some I/O pins will still need to be connect ed in HAL for the limit switches and probe input for example:
Are all GPIO
P3 pin GPIO G540
1 0 OUTPUT2
10 13 INPUT1
11 14 INPUT2
12 15 INPUT3
13 16 INPUT4
15 6 DRIVE FAULT
17 7 OUTPUT1
Are all GPIO
Last edit: 23 Apr 2013 06:58 by PCW.
- pws
23 Apr 2013 07:36 #33035
by pws
I see. That's great info! Is it documented in detail anywhere?
Thanks,
Paul
Thanks,
Paul
23 Apr 2013 08:27 #33037
Sure, the g540x2.pin file (or the dmesg log from linuxCNC)
and the Gecko G540 manual
23 Apr 2013 19:20 #33057
The definitive source is dmesg, that lists exactly what your particular config string causes each pin is allocated as.
So, after starting up LinuxCNC, in the terminal, just type "dmesg". Lots of useful info there.
- pws
24 Apr 2013 02:41 - 24 Apr 2013 04:25 #33085
by pws
I finally found an answer to my first issue:
Replace: net estop-out => hm2_[HOSTMOT2](BOARD).0.pin-001
With: net estop-out => hm2_[HOSTMOT2](BOARD).0.gpio.001.out
seems to get me beyond that point.
Now I have one I cannot seem to understand!
grizz-6i25.hal:109: Pin 'hm2_5i25.0.stepgen.00.enable' does not exist
What have I blindly missed now?
Startup is rough!!!
Thanks,
Paul
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.2
Machine configuration directory is '/home/pws/linuxcnc/configs/grizz-mill'
Machine configuration file is 'grizz-6i25.ini'
INIFILE=/home/pws/linuxcnc/configs/grizz-mill/grizz-6i25.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=2592
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
2592
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 5824.344580] I-pipe: Domain RTAI registered.
[ 5824.344584] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 5824.344586] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 5824.344722] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5824.344723] PIPELINE layers:
[ 5824.344725] fac15e20 9ac15d93 RTAI 200
[ 5824.344727] c085cb20 0 Linux 100
[ 5824.354698] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5824.355057] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 5824.355060] RTAI[sched]: hard timer type/freq = APIC/6250559(Hz); default timing: periodic; linear timed lists.
[ 5824.355062] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3800394000 hz.
[ 5824.355063] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 5824.355110] RTAI[usi]: enabled.
[ 5824.372127] RTAI[math]: loaded.
[ 5824.413871] hm2: loading Mesa HostMot2 driver version 0.15
[ 5824.415496] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 5824.415526] hm2_pci 0000:02:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 5824.415529] hm2_pci: discovered 5i25 at 0000:02:00.0
[ 5824.416043] hm2/hm2_5i25.0: Smart Serial Firmware Version 38
[ 5824.471625] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 5824.471627] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 5824.471629] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 5824.471630] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 5824.471632] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 5824.471633] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 5824.471635] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 5824.471636] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 5824.471638] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 5824.471639] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 5824.471641] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 5824.471642] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 5824.471645] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 5824.471646] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 5824.471648] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 5824.471649] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 5824.471651] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 5824.471653] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 5824.471655] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 5824.471657] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 5824.471658] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 5824.471660] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 5824.471661] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 5824.471663] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 5824.471664] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 5824.471665] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 5824.471667] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 5824.471668] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 5824.471670] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 5824.471671] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 5824.471672] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 5824.471674] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 5824.471675] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 5824.471676] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 5824.471678] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 5824.471705] hm2/hm2_5i25.0: registered
[ 5824.471707] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
[ 5824.649712] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
[ 5824.649716] hm2/hm2_5i25.0: unregistered
[ 5824.649738] hm2_pci 0000:02:00.0: PCI INT A disabled
[ 5824.649759] hm2_pci: driver unloaded
[ 5824.651181] hm2: unloading
[ 5824.673993] RTAI[math]: unloaded.
[ 5824.684552] SCHED releases registered named ALIEN RTGLBH
[ 5824.748328] RTAI[malloc]: unloaded.
[ 5824.848198] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5824.850277] I-pipe: Domain RTAI unregistered.
[ 5824.850444] RTAI[hal]: unmounted.
Startup is rough!!!
Thanks,
Paul
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.2
TASK=milltask
HALUI=
DISPLAY=axis
Cleanup done
2592
Last edit: 24 Apr 2013 04:25 by pws.
Time to create page: 0.101 seconds
