MESA 5i23 7i44 7i49 7i37 8i20
28 May 2015 02:11 - 28 May 2015 02:12 #59120 by kenny
Replied by kenny on topic MESA 5i23 7i44 7i49 7i37 8i20
Ok, thank you.
Maybe I will next weekend "debug" on the machine. ;)
Unfortunatelly, I still dont have xml file for my machine.
My idea:
Step one: I will configurate my machine via pcconf (very briefly configuration)
Step two: And then I will firmly tuning HAL and INI files by yours posts.
My question is: is possible downloaded rmsvss6_8.xml file for my 5i23?
thank
Last edit: 28 May 2015 02:12 by kenny.
28 May 2015 02:25 #59123 by andypugh
Replied by andypugh on topic MESA 5i23 7i44 7i49 7i37 8i20
Looking at pncconf it seems to understand bldc and resolvers, though it would be interesting to see whether it gets closer to a working config on your machine than my config is.
28 May 2015 02:51 #59124 by kenny
Ok, I'll try it, and then sends a message. :)
Ehm,
But I still want to try pcconf... ;)
Xml....
28 May 2015 06:18 #59137 by andypugh
Well, yes, but without the XML file that is difficult.
28 May 2015 11:29 #59141 by kenny
I understand.
Nothing XML.
Nothing pncconf...
ASCII text editor and: Linux forever. :(
18 Jun 2015 22:45 #59947 by kenny
Hi, do you help Me please?
I have little problem with file Mymachine.hal
1) I wrote you configuration to my HAL file for first testing.
2) I change line with load firmware to Mesa 5i23 to> loadrt hm2_pci config="firmware=hm2/5i23/RMSVSS6_8.bit" pass OK
3) I dont know to change (replace) this line > loadrt bldc cfg=[HAL]BLDC but pass NOK...
Thank you
18 Jun 2015 22:59 #59949 by andypugh
You need to add a section to your INI file called [HAL] (if you don't already have one) and then add an entry for BLDC in that.
In the HAL file anything that looks like [THIS]AND_THIS means that the HAL file should look in the [THIS] section of the INI for an entry called AND_THIS.
(You can add anything you want, but some of the existing entried have special meanings.
The [HAL]BLDC entry should be the config string for the bldc component appropriate to your motors.
18 Jun 2015 23:35 #59955 by kenny
Thank,
do you send me please example of parts on this BLDC config?
I have files Mymachine.hal and Mymachine.ini but I dont have correctlysection for 7i49 and sin cos resolver... (maybe?)
19 Jun 2015 00:09 #59959 by andypugh
My config is pretty complicated by now, so giving you all of it might not help.
Resolvers are absolute devices, so it's very simple:
BDLC = a,a,a
19 Jun 2015 17:22 #59978 by kenny
Ok,
sorry I am totaly newbie in linuxcnc - emc - mesa... :(
But I gradually perfected (step by step by...). ;)
So, this is part of my hal file:
loadrt trivkins
loadrt motmod servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt bldc =a,a,a
loadrt pid num_chan=4
loadrt sum2 count=1
loadrt logic names=estop-sw personality=0x103
loadrt oneshot
loadrt near count=1
loadrt and2 countloadrt bldc count=3=1
loadrt or2 count=1
setp hm2_5i23.0.watchdog.timeout_ns 10000000
Is it OK?
Moderators: PCW, jmelson
Time to create page: 0.162 seconds
