MESA 5i23 7i44 7i49 7i37 8i20
14 Jul 2015 05:30 #60618
In the INI file.
You don't actually have to get them from the INI file, you can use numerical values directly in the HAL file, but if you want to use the INI file then the format [AXIS_0]PGAIN refers to the entry PGAIN = 1.23445 in the [AXIS_0] section of the INI file.
Replied by andypugh on topic MESA 5i23 7i44 7i49 7i37 8i20
Question is: where is defined variable "[AXIS_0]PGAIN" and next variable IGAIN DGAIN etc.. ?
In the INI file.
- kenny
14 Jul 2015 23:09 #60622
by kenny
Replied by kenny on topic MESA 5i23 7i44 7i49 7i37 8i20
My next question is:
There are some basic (recommended) values for the first step?
What is the range of values?
Only for first testing.
setp pid.0.Pgain [AXIS_0]PGAIN
setp pid.0.Igain [AXIS_0]IGAIN
setp pid.0.Dgain [AXIS_0]DGAIN
setp pid.0.bias [AXIS_0]BIAS
setp pid.0.FF0 [AXIS_0]FF0
setp pid.0.FF1 [AXIS_0]FF1
setp pid.0.FF2 [AXIS_0]FF2
setp pid.0.deadband [AXIS_0]DEADBAND
setp pid.0.maxoutput [AXIS_0]MAXOUTPUT
Are there any manual?
Thank You.
Thank You.
14 Jul 2015 23:54 #60623
It depends on the system being tuned. I have seen Pgains from 0.0001 to 10,000 and there is no reason that the "right" value shouldn't be higher or lower.
The units of Pgain (in your case) are amps per engineering unit. So I would say that as a starting point, to make sure that things move in the right direction, you could try everything at zero apart from Pgain, then set that at 0.1 for an inch machine, and 0.005 for a metric one. That should be fairly slow to respond, but should move in the right direction.
But as a starting point, have a look at:
www.gnipsel.com/linuxcnc/tuning/torque.html
There are many text books on PID tuning, and it can make up most of a degree course. I have a colleague with a PhD in the subject...Are there any manual?
- kenny
15 Jul 2015 00:07 #60624
by kenny
PID is a complex issue.
OK.
But, I'm looking for a manual about the configuration HAL file (with MESA servo) and his parameters.
OK.
- kenny
15 Jul 2015 00:14 #60625
by kenny
linuxcnc.org/docs/html/config/ini_config.html
Via www.gnipsel.com/linuxcnc/tuning/torque.html
It is good link.
It is good link.
15 Jul 2015 00:20 #60626
Have you found this page yet? Links to everything...
www.linuxcnc.org/docs/html/
If you are using the axis GUI then you might find the Machine -> Calibration menu option useful, it lets you change the PID settings then write the new values back to the INI file.
The following user(s) said Thank You: kenny
- kenny
15 Jul 2015 00:22 #60627
by kenny
Thank you, I'll look at it.
- kenny
17 Jul 2015 22:00 #60690
by kenny
I have axis configuration (very basicly) OK.
I still don have configuratition E-stop pin(s) and Machine ON.
#E-Stop and machine-on
setp oneshot.0.falling 1
setp oneshot.0.rising 0
setp oneshot.0.retriggerable 1
setp oneshot.0.width 10 #10 second delay before machine can be on after off.
net estop-sw0 estop-sw.in-00 hm2_5i23.0.7i37.0.0.input-06-not
net estop-sw1 estop-sw.in-01 hm2_5i23.0.7i37.0.0.input-07-not
net estop-sw2 estop-sw.in-02 <= oneshot.0.out-not
net estop-loop estop-sw.and => iocontrol.0.emc-enable-in
net amp-enable joint.0.amp-enable-out oneshot.0.in
Servo Power (08) 8i20-enable 12
net amp-enable hm2_5i23.0.7i37.0.0.output-08 hm2_5i23.0.7i37.0.0.output-12
Do You help Me please?
I need very simple configuration.
Thank
Thank
17 Jul 2015 22:51 #60693
The simplest configuration is just a simple loopback like the sim configs use.
But you probably don't want that for an actual live system, you do want the e-stop to work.
It is impossible for me to suggest a config without knowing how your e-stop is wired.
- kenny
17 Jul 2015 23:38 #60695
by kenny
Please suggest me simple (only sw) solution for E-stop and machine ON Signal.
I have 5I23 and 7I37-TA on port3. All pins in7I37 is still free for use.
Complete emergency circuit is designed and wired in machine, but is not working because machine is still not moving.
Thank You.
Thank You.
Time to create page: 0.163 seconds
