MESA 5i23 7i44 7i49 7i37 8i20
19 Jun 2015 17:29 #59980
No.
The manual page for bldc is here:
www.linuxcnc.org/docs/html/man/man9/bldc.9.html
You can see that the correct format is
loadrt bldc cfg="a,a,a"
Please read that manpage, bldc will make no sense at all without it.
Every other HAL component has a similar page, they are listed near the bottom of here:
I go to those pages all the time to find out exactly what the pin names are. Have a good look at the pins of the"motion" module too.
Replied by andypugh on topic MESA 5i23 7i44 7i49 7i37 8i20
loadrt bldc =a,a,a
Is it OK?
No.
- kenny
19 Jun 2015 17:40 #59982
by kenny
Replied by kenny on topic MESA 5i23 7i44 7i49 7i37 8i20
Thank you for links.
I go to study.
I go to study.
- kenny
29 Jun 2015 22:29 #60254
by kenny
I am in next step of configuration my machine.
And next error:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.4
Machine configuration directory is '/home/emc2/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/emc2/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=5079
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/bldc.ko: File exists
my_LinuxCNC_machine.hal:9: exit value: 1
my_LinuxCNC_machine.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
5079
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
What does it mean?
You can not find a solution.
Thank
And next error:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.6.4
TASK=milltask
HALUI=halui
DISPLAY=axis
5079
What does it mean?
Thank
29 Jun 2015 22:37 #60256
It sounds like you have more than one "loadrt bldc...." in the HAL file.
The following user(s) said Thank You: kenny
- kenny
29 Jun 2015 22:55 #60257
by kenny
Thank
These two lines in hal generated err.
loadrt bldc count=3
Second line was deleted.
OK.
And next err is here:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.6.4
TASK=milltask
HALUI=halui
DISPLAY=axis
Killing task linuxcncsvr, PID=5413
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/and2.ko: Unknown symbol in module
my_LinuxCNC_machine.hal:16: exit value: 1
my_LinuxCNC_machine.hal:16: insmod failed, returned -1
5413
Help me please.
Thank
loadrt bldc count=3
OK.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.6.4
TASK=milltask
HALUI=halui
DISPLAY=axis
5413
Help me please.
Thank
29 Jun 2015 23:13 #60258
Sounds like a funny "loadrt and2" line.
man and2 to see the allowed module parameters
- kenny
30 Jun 2015 00:37 #60259
by kenny
Previous err was solved.
Thank you, but many bugs before me...
1st bug :
my_LinuxCNC_machine.hal:54: Pin 'joint.0.vel-cmd' does not exist
8958
Segment of my HAL:
# +++++++X Axis+++++++++
net res-x-cnts hm2_5i23.0.resolver.01.rawcounts => bldc.0.rawcounts
net x-index hm2_5i23.0.resolver.01.index-enable <=> pid.0.index-enable
#net x-home-lim hm2_5i23.0.7i37.0.0.input-14-not => joint.0.pos-lim-sw-in joint.0.neg-lim-sw-in joint.0.home-sw-in
net x-meas-angle bldc.0.rotor-angle => hm2_5i23.0.8i20.0.2.angle
setp hm2_5i23.0.8i20.0.2.current-maxlim 7.5
setp hm2_5i23.0.8i20.0.2.current-minlim -7.5
net x-cmd axis.0.motor-pos-cmd => pid.0.command
net x-vel-cmd joint.0.vel-cmd => pid.0.command-deriv
net x-fb hm2_5i23.0.resolver.01.position pid.0.feedback axis.0.motor-pos-fb
net x-vel-fb hm2_5i23.0.resolver.01.velocity pid.0.feedback-deriv
setp hm2_5i23.0.resolver.01.velocity-scale -1
net x-pid pid.0.output => hm2_5i23.0.8i20.0.2.current
2nd bug:
my_LinuxCNC_machine.hal:64: Ini variable '[JOINT_0]PGAIN' not found.
9146
Segment of HAL:
net amp-enable pid.0.enable
setp pid.0.Pgain [JOINT_0]PGAIN
setp pid.0.Igain [JOINT_0]IGAIN
setp pid.0.Dgain [JOINT_0]DGAIN
setp pid.0.bias [JOINT_0]BIAS
setp pid.0.FF0 [JOINT_0]FF0
setp pid.0.FF1 [JOINT_0]FF1
setp pid.0.FF2 [JOINT_0]FF2
setp pid.0.deadband [JOINT_0]DEADBAND
setp pid.0.maxoutput [JOINT_0]MAXOUTPUT
Do you help me please?
1st bug :
8958
Segment of my HAL:
2nd bug:
9146
Segment of HAL:
30 Jun 2015 03:06 #60265
You are using a joints-axes style configuration with a "traditional" LinuxCNC version, and that is never going to work, because the INI file format is different and the HAL pins are different.
Your HAL file for each axis needs to look like Post 59117
- kenny
30 Jun 2015 03:20 #60266
by kenny
OK, I understand.
- kenny
14 Jul 2015 00:52 #60617
by kenny
I wrote my hal file for each axis: Post 59117
And LinuxCNC generated this error:
my_LinuxCNC_machine.hal:65: Ini variable '[AXIS_0]PGAIN' not found.
line 65 is: "setp pid.0.Pgain [AXIS_0]PGAIN"
Question is: where is defined variable "[AXIS_0]PGAIN" and next variable IGAIN DGAIN etc.. ?
Thank You.
Thank You.
Time to create page: 0.254 seconds
