Spinx1 to 7i85
24 Oct 2015 02:31 #64195 by OT-CNC
Spinx1 to 7i85 was created by OT-CNC
I need help with my final connections on the Spinx to 7i85.
I have TB-1 differential out 6+7 available on the 7i85 for connecting the 3 wires from the spinx ( PWM, Enable and Dir.) What goes where??
TB-1 pins 9 and 10 are ground, 11 is TX6, 12 is /TX6, 13 TX7, 14 /TX7, 15 and 16 are +.
All the jumpers are in the down position for the encoders that are connected to the 7i85 in case that info matters for the outputs.
Once connected, how do I assign the proper pwm on the pwm pin? 5i25, 7i85s and field i/o boards are used.
24 Oct 2015 03:25 #64196 by PCW
Replied by PCW on topic Spinx1 to 7i85
well, you will need one more signal
assuming you dont use DIR for now
you could wire
PWM to TX6- and /ENA to TX7-
To get hardware PWM on those pins requires the proper firmware
what firmware are you using?
24 Oct 2015 04:56 #64198 by OT-CNC
Replied by OT-CNC on topic Spinx1 to 7i85
PCW,
I have configuration: 7i85Sx2.BIT according to the sticker in the back of the 5i25 board.
Other output pins that are available are on my 7i84. Would that be easier to implement? Actually I'm running these on 24v so probably not.
Actually I do have an additional differential out 2 and 3 on tb2 that are available. Can I wire direction to TX-2?
25 Oct 2015 03:28 #64238 by OT-CNC
Hi PCW,
What firmware do I need?
If I need something custom, can you help me with getting the proper configuration based on the pins I listed? And a link to how to flash the board?
Thank you very much in advance.
26 Oct 2015 20:30 #64290 by andypugh
Replied by andypugh on topic Spinx1 to 7i85
git.linuxcnc.org/gitweb?p=hostmot2-firmw...0a04b7f5d9df;hb=HEAD
Shows that there are no pwmgens on 7i85Sx2
7i85SPx2 _does_ have PWMgens, but no stepgens.
git.linuxcnc.org/gitweb?p=hostmot2-firmw...97adc0d8ccbd;hb=HEAD
In theory you could combine those two files to create a firmware with a mixture of stepgens and pwmgens. There are instruction in the README file at the top level:
git.linuxcnc.org/gitweb?p=hostmot2-firmware.git;a=tree
In practice it is probably easier to ask PCW nicely for a custom firmware, unless he has already made one.
To get going quickly you could use a software pwmgen, with a 1000Hz servo thread you will only get about 10 discrete PWM values even at 50Hz PWM frequency, but it will at least allow you to check out the system.
27 Oct 2015 01:51 #64321 by OT-CNC
andypugh,
Thank you for the links.
My preference would be to have PCW make a custom firmware.
27 Oct 2015 22:25 #64351 by OT-CNC
An option I didn't consider is the secondary 26 pin connector on the 5i25 (P2) as it will be a messy wire termination inside the pc without some screw terminals to mount to.
Can I get the required pwm out on that connector without firmware change?
27 Oct 2015 22:30 #64352 by andypugh
No, you still need a firmware change. At the moment the internal connector is configured for a second 7i85S with Step/Dir.
To wire neatly to that internal connector you need: store.mesanet.com/index.php?route=produc...74_79&product_id=235 or from a non-mesa source: www.amazon.com/CableWholesale-Motherboar...ds=parallel+port+idc
27 Oct 2015 22:41 #64353 by OT-CNC
andypugh,
Thanks for the clarification on that. I was about to start wiring lol...
Okay, so in that case I will need a new configuration and will wire to the 7i85 as originally intended.
The 5i25 manual shows a JTAG connection for programming. Do I need to get that connector for updating the firmware???
27 Oct 2015 22:50 #64354 by andypugh
No, you can re-program in the PC with the "mesaflash" utility.
Instructions are in the 5i25 manual, Page 12: www.mesanet.com/pdf/parallel/5i25man.pdf
Moderators: PCW, jmelson
Time to create page: 0.248 seconds
