Spinx1 to 7i85
22 Aug 2016 19:50 #79275 by OT-CNC
Replied by OT-CNC on topic Spinx1 to 7i85
I just looked over the glade tutorials and I don't follow how I can change the layout from being embedded as as tap in axis to being next to axis.
in the ini:
[DISPLAY]
GLADEVCP= -u handler.py example.glade
I assume example.glade needs to be replaced with something relevant to my panels. What do I change?
As is, the panel displays in an embedded tab and I want it on the main axis screen.
22 Aug 2016 22:01 #79283 by andypugh
Replied by andypugh on topic Spinx1 to 7i85
[DISPLAY]
I assume example.glade needs to be replaced with something relevant to my panels..
Are you saying that the code above results in an embedded tab?
linuxcnc.org/docs/2.7/html/gui/gladevcp....into_axis_like_pyvcp
Says that that should put it in the right-side frame.
Are you sure you are editing the correct INI file?
23 Aug 2016 02:06 #79290 by OT-CNC
Sorry I wasn't clear. No, that code was supposed to put it on the axis screen.
I forget the exact error message but something along the lines of example.glade not found.
I'll try again with your info/link. I was looking at another manual earlier that was very condensed.
Let me know if I'm getting off topic posting here as additional lathe specific questions arise. As far as SpinX1 is concerned, that is a working.
I may have a dia/radius issue since the upgrade as G7 is not putting me into dia mode. The x axis jog increments reflect radius mode only. Are there any other M or G codes that could prevent me getting into dia mode??
23 Aug 2016 08:12 - 23 Aug 2016 08:13 #79298 by andypugh
Yes, the files that you are trying to load do have to exist...
Last edit: 23 Aug 2016 08:13 by andypugh.
25 Aug 2016 03:09 #79393 by OT-CNC
Got the glade panel working. I just changed the following in the ini file under (display):
Removed the two embed_tab lines and replaced it with GLADEVCP = -H gvcp_call_list.hal gvcp-panel.ui
And left the other code in the gvcp_options.hal and custom_postgui.hal alone.
Also, everything is fine with G7 and G8. I confirmed it with a dial indicator.
Moderators: PCW, jmelson
Time to create page: 0.096 seconds
