Spinx1 to 7i85
- OT-CNC
- Thank you received: 75
The index value is false and the status led is brown under the hal config show/watch tabs.
Index pulse shows up in Hal Scope.
I have this in my hal:
net spindle-index-enable hm2_5i25.0.encoder.03.index-enable <=> motion.spindle-index-enable
I have also tried:
net spindle.index-enable hm2_5i25.0.encoder.03.index-enable <=> motion.spindle-index-enable
Both hang at the same point.
- Thank you received: 5325
if its not true, motion will pause
BTW
and
and
net some-wierd-old-name hm2_5i25.0.encoder.03.index-enable <=> motion.spindle-index-enable
are identical (as long as the net name is only used in that line) That is, net names have no meaning
other than as a way of connecting pins together
- OT-CNC
I know it's not configured correctly. motion.spindle-at-speed is now true all the time and still hangs. Maybe I should re-do a standard spindle config to get threading and css to work then patch in the spindle orient that is currently working? Andy, is your vismach config working for tapping? I know it was originally intended for mill application and I'm trying it on a lathe.
- Thank you received: 4654
The Vismach config is very much a visualisation and simulator config. I can imagine that much of it will be entirely wrong for real hardware, but I hope I put meaningful comments in the spindle.hal to explain the differences?
- OT-CNC
Also, on the examples I see posted, many use only the A channel and an Index. I have a 2048 count encoder in quad mode, 8192 encoder scale. Do I need to re-set the mode to only read A? What is the max rpm that I can expect linuxcnc with mesa hardware to keep track of the rpm with my encoder? Do I need lower resolution on the spindle? Obviously for position low res would not be good.
and are good to about 1-2 millions counts per second so 8192 counts
at say 8000 RPM is fine
If you want a spindle-at-speed signal then another "near" would be needed, but otherwise it isn't necessary.I think the near component is missing in the velocity closed loop section? I see a near component in the position section.
If you want to do tapping you absolutely need the B channel too, so that the system can tell when the spindle has reversed.Also, on the examples I see posted, many use only the A channel and an Index. I have a 2048 count encoder in quad mode, 8192 encoder scale. Do I need to re-set the mode to only read A?
What is the max rpm that I can expect linuxcnc with mesa hardware to keep track of the rpm with my encoder?.
If you turn off the filter then it is 160,000 rpm. I don't think you need to worry about it
- OT-CNC
- OT-CNC
I will try to take this config and add it to the previous to get the spindle orient t work. I'm sure I'll manage to mess it up at some point .
The only thing that didn't configure is the glade spindle rpm panel and at speed led. Anything obvious I need to check for that to display correctly?
Check the connections i custom_postgui.hal (and that the INI file specifies a POSTGUI_HALFILE)
