Mesa 6i25 not working?
- ebe2305
15 Nov 2015 09:56 #65272
by ebe2305
Replied by ebe2305 on topic Mesa 6i25 not working?
Hi Micges,
Flashing the 6i25 was done with the linuxcnc live cd. It is the 2.7 wheezy linuxcnc I have used.
As far as i know that version is 32bit. FYI.
Greets Volker
Greets Volker
- ebe2305
17 Nov 2015 19:34 #65394
by ebe2305
Hi micges thank you once more for your time you have spend with me figuring out the 6i25 is working now....
THE 6i25 IS WORKING NOW!
First I thought it was due to a System update where new kernels where installed.
But now I figured out it is related on how the Installation of Linux was done.
Installing with UEFI Bios --> 6i25 not working.
Installing with Legacy Bios --> 6i25 is working.
This was selectable on bootmenue of my Mainboard, but first not recognized by me.
For now everything is ok on my System.
Greets Volker
Greets Volker
The following user(s) said Thank You: aleksamc
- sorokin_pro
26 Dec 2025 00:41 #340508
by sorokin_pro
Replied by sorokin_pro on topic Mesa 6i25 not working?
I have similar problem; tried 2 PCs. On both 6i25 is disabled in UEFI and enabled in legacy mode. Tried switching between 5i25 and 6i25 modes.
But mesaflash reports that no boards are found.
Attached output of dmesg and lspci commands.
I am using latest Debian version from LinuxCNC website.
- Thank you received: 7485
26 Dec 2025 01:12 #340509
Replied by tommylight on topic Mesa 6i25 not working?
From your lspciThat is the 5i25.
02:00.0 DPIO module [1100]: Device [2718:5125] (rev 01)
Subsystem: Device [2718:5125]
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 11
Region 0: Memory at f7e00000 (32-bit, non-prefetchable) [size=64K]Please Log in or Create an account to join the conversation.
- Thank you received: 5328
26 Dec 2025 02:36 #340511
Replied by PCW on topic Mesa 6i25 not working?
The lspci report indicates the the board is accessible (as a 5I25)
Make sure that you leave the 6I25 jumpered for 5I25 mode or you will have access issues.
- sorokin_pro
26 Dec 2025 17:24 #340527
by sorokin_pro
26 Dec 2025 17:30 - 26 Dec 2025 17:31 #340528
That will likely not work, (not meet timing) you must jumper the card for 5I25 mode to use 5I25 firmware (the default)
Last edit: 26 Dec 2025 17:31 by PCW.
The following user(s) said Thank You: maxi177
- sorokin_pro
26 Dec 2025 17:37 #340530
by sorokin_pro
I just switched to default jumper positions:
Result is still the same:
dmesg and lspci outputs are provided.
W1 DOWN
W2 DOWN
W3 UP
W4 UP
W5 UP
W7 DOWN
W8 UPResult is still the same:
user@denc:~$ mesaflash --device 6I25
No 6I25 board found
user@denc:~$ mesaflash --device 5I25
No 5I25 board founddmesg and lspci outputs are provided.
26 Dec 2025 18:18 #340534
Does LinuxCNC see the card?
- sorokin_pro
26 Dec 2025 18:32 #340536
by sorokin_pro
This is the part I did not figure out for now.
I tried loading the configuration from PnCconf, but LinuxCNC crashed because some timer was not found. I commented out two lines in the .ini file, and LinuxCNC launched, but I do not know where I can see if it found the card.
Should I just try running some G-code?
This is my first time with MESA and LinuxCNC, but I have experience with industrial CNC machines, 3D printers, Linux, software development, and electronics.
Time to create page: 0.222 seconds
