Mesa 6i25 not working?
  • Moderator
  • Moderator
26 Dec 2025 19:02 #340538 by tommylight
Replied by tommylight on topic Mesa 6i25 not working?
The config generated by PncConf, edit the .hal file with a text editor (not libreoffice) and omit or delete the line containing DPLL timer, savem start the config again.
26 Dec 2025 19:48 #340543 by PCW
Replied by PCW on topic Mesa 6i25 not working?
If you launch LinuxCNC from the command line, you will get a list as the hardware is discovered
which should help with debugging
The timer issue is possibly  that the installed firmware lacks a DPLL timer
(and pncconf always puts DPLL timer boilerplate in the hal file)
 You can work around this by deleting (or commenting out)  any lines that
mention "dpll" in the hal file
26 Dec 2025 21:44 - 26 Dec 2025 21:45 #340545 by sorokin_pro
Replied by sorokin_pro on topic Mesa 6i25 not working?
Looks like LinuxCNC detects the board:
user@denc:~$ linuxcnc
LINUXCNC - 2.9.7
Machine configuration directory is '/home/user/linuxcnc/configs/BenchtopX5'
Machine configuration file is 'BenchtopX5.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./BenchtopX5.hal
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:02:00.0
hm2/hm2_5i25.0: Low Level init 0.15
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:02:00.0
Found file(REL): ./custom.hal
link (updating variable file): No such file or directory
No option 'tto_g11' in section: 'DEFAULT'
No option 'show_program' in section: 'DEFAULT'
No option 'show_rapids' in section: 'DEFAULT'
No option 'program_alpha' in section: 'DEFAULT'
No option 'show_live_plot' in section: 'DEFAULT'
No option 'show_tool' in section: 'DEFAULT'
No option 'show_extents' in section: 'DEFAULT'
No option 'show_offsets' in section: 'DEFAULT'
No option 'grid_size' in section: 'DEFAULT'
No option 'show_machine_limits' in section: 'DEFAULT'
No option 'show_machine_speed' in section: 'DEFAULT'
No option 'show_distance_to_go' in section: 'DEFAULT'
No option 'dro_large_font' in section: 'DEFAULT'
No option 'block_delete' in section: 'DEFAULT'
No option 'optional_stop' in section: 'DEFAULT'
note: MAXV max: 25.000 units/sec 1500.000 units/min
note: LJOG max: 25.000 units/sec 1500.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
note: AJOG max: 180.000 units/sec 10800.000 units/min
note: AJOG default: 12.000 units/sec 720.000 units/min
note: jog_order='XYZA'
note: jog_invert=set()
Would be great if mesaflash also could detect it.
Last edit: 26 Dec 2025 21:45 by sorokin_pro.
26 Dec 2025 21:49 #340546 by PCW
Will mesaflash recognize the card after LinuxCNC has run?
(I've seen this before with some BIO's that detect the card but for some reason disable the cards memory region)
26 Dec 2025 22:02 #340548 by sorokin_pro
No:
user@denc:~$ mesaflash --device 5I25
No 5I25 board found
LINUXCNC - 2.9.7
Waiting for component 'tpmod' to become ready..........Waited 3 seconds for master.  giving up.
.Note: Using POSIX realtime
Running HAL shutdown script
task: 1471 cycles, min=0.000007, max=0.031596, avg=0.010006, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_5i25.0: dropping AnyIO board at 0000:02:00.0
hm2/hm2_5i25.0: unregistered
RTAPI_PCI: Unmapped 65536 bytes at 0x7fc2736fd000
hm2_pci: driver unloaded
hm2: unloading
No 5I25 board found
26 Dec 2025 22:16 #340549 by PCW
You need to use sudo with mesaflash when accessing PCI cards
26 Dec 2025 22:20 #340550 by sorokin_pro
I just tried with and without sudo, I also tried while LinuxCNC is running.
Result is the same all the time:
No 5I25 board found
user@denc:~$ sudo mesaflash --device 5I25
[sudo] password for user:
No 5I25 board found
26 Dec 2025 22:46 #340552 by PCW
Do get a warning when not using sudo?
If not, something really basic is broken here.
pcw@pcw-HP-Compaq-Elite-8300-USDT:~$ mesaflash --device 5i25
You need root privileges (or setuid root) to access PCI hardware
No 5I25 board found
What version of mesaflash do you have?
  • Moderator
  • Moderator
26 Dec 2025 22:53 #340554 by tommylight
i
is not
I
5i25 is not 5I25
Linux is case sensitive.
26 Dec 2025 23:27 #340556 by sorokin_pro
5i25 is not 5I25
Here is a piece of code from mesaflash:
access.device_name[i] = toupper(access.device_name[i]);
Device names are converted to upper case automatically.
Moderators: PCW, jmelson
Time to create page: 0.167 seconds
