Mesa 7i90 in SPI mode
10 years 7 months ago - 10 years 7 months ago #71321 by kaklik
Mesa 7i90 in SPI mode was created by kaklik
Hello,
I have Mesa 7i90HD card and I want to connect it to ODROID-C1 computer running LinuxCNC. The ODROID-C1 has 3,3V compatible l/O, therefore I connected the 7i90HD card directly on ODROID's SPI interface without voltage translator.
I supposed it must working instantly, because it is almost exactly same system as there: github.com/jepler/u3-7i90/blob/master/eagle/oddspi-sch.pdf
But I have problem with SPI communication with Mesa card, the card does not response to input SPI data. If I load the hm2_spi driver by these commands:
loadrt hostmot2
loadrt hm2_spi spidev_path="/dev/spidev0.0" spidev_rate=500
I got the invalid cookie error, which is obviously related to the fact that mesa card does not respond anything on input data. How can I make the mesa card talking on SPI. Do I need to switch a communication mode on a new card by some procedure?
Note: Using POSIX non-realtime hm2: loading Mesa HostMot2 driver version 0.15 probing device /dev/spidev0.0 with rate 500000 Hz Invalid cookie Read: ffffffff ffffffff ffffffff ffffffff hm2_spi: rtapi_app_main: No such device (-19) mesa_test.hal:2: waitpid failed /home/odroid/repos/linuxcnc-MLAB/bin/rtapi_app hm2_spi mesa_test.hal:2: /home/odroid/repos/linuxcnc-MLAB/bin/rtapi_app exited without becoming ready mesa_test.hal:2: insmod for hm2_spi failed, returned -1
I attach several oscilloscope images:
Blue line shows data from odroid (Connected to PIN 13 of MESA P4 connector) and yellow line is SPICLK signal at PIN11 of P4 connector.
Here blue line is a SPIOUT at PIN 15 and yellow line SPICLK again.
Here is overall look at the test setup:
Last edit: 10 years 7 months ago by kaklik.
10 years 7 months ago - 10 years 7 months ago #71324 by PCW
Replied by PCW on topic Mesa 7i90 in SPI mode
Do you have a bitfile with a SPI host interface loaded in the FPGA?
Also you are very likely to suffer from signal integrity issues unless you use a flat cable
from the 7I90s host interface connector and terminate _all_ the ground pins in that cable
at the ODROID
Last edit: 10 years 7 months ago by PCW.
10 years 7 months ago #71328 by kaklik
Replied by kaklik on topic Mesa 7i90 in SPI mode
PCW wrote: Do you have a bitfile with a SPI host interface loaded in the FPGA?
Presumably no. I am using a bitfile shipped in the card's EEPROM memory.. I have read the manual www.mesanet.com/pdf/parallel/7i90hdman.pdf and I do not know what bitfile is flashed in to the new board..
Should I use mesaflash to load some another bitfile in to the 7I90 board? It seems I should obtain a RS-422 adapter or a computer with LPT interface which I could connect to mesa's LBP16/EPP interface...
PCW wrote: Also you are very likely to suffer from signal integrity issues unless you use a flat cable
at the ODROID
Yes, I have this in mind, I verified the signal integrity by oscilloscope and it seems to be adequate for current configured speed. I will modify the test setup for higher SPI speeds after I get some data from the mesa board.
10 years 7 months ago #71342 by PCW
7I90s are shipped with EPP configurations in both EEPROMS,
You would need to flash a card with a SPI configuration to test SPI operation
Note that as far as I know, only EPP is know to work with mesaflash,
so make sure you leave a EPP configuration on one EEPROM
The following user(s) said Thank You: kaklik
  • jepler
  • Administrator
  • Administrator
10 years 7 months ago #71344 by jepler
Replied by jepler on topic Mesa 7i90 in SPI mode
In 2014 I contributed spi support to mesaflash. At least at the time, it did work, I reported in the commit message that it successfully programs and verifies my 7i90 on SPI. But of course you can't use this for initial programming, when the board is shipped with an EPP firmware.
Within the last 6 months I have used odroid u3 + 7i90 over spi to move a motor, so I think the code in linuxcnc is still working properly.
10 years 7 months ago #71345 by kaklik
Ok, I will try to upload a SPI based configuration to the FPGA. I downloaded the software support package: www.mesanet.com/software/parallel/7i90.zip , but there are many bitfiles which have 'spi' keyword in name..
7i90_spi_24xqctronly.bit 7i90_spi_2x7i65.bit 7i90_spi_da2.bit 7i90_spi_justio.bit 7i90_spi_sssv6_36.bit 7i90_spi_sssvst8_1_5_7i47.bit 7i90_spi_sssvst8_8_8.bit 7i90_spi_st12.bit 7i90_spi_st18.bit 7i90_spi_st8_plasma.bit 7i90_spi_sv12.bit 7i90_spi_sv12im_2x7i48.bit 7i90_spi_sv4_7i47s.bit 7i90_spi_sv6_7i49.bit 7i90_spi_svsp8_6_7i46.bit 7i90_spi_svss6_6.bit 7i90_spi_svss6_8.bit 7i90_spi_svss8_44.bit 7i90_spi_svss8_8.bit 7i90_spi_svst1_4_7i47s.bit 7i90_spi_svst1_4_7i47sd.bit 7i90_spi_svst1_5_7i47.bit 7i90_spi_svst2_4_7i47.bit 7i90_spi_svst2_4_7i47d.bit 7i90_spi_svst4_8_ado.bit 7i90_spi_svst4_8.bit 7i90_spi_svst6_6_7i52s.bit 7i90_spi_svst6_6_7i52sd.bit 7i90_spi_svst8_12_2x7i47.bit 7i90_spi_svst8_4.bit 7i90_spi_svst8_4im2.bit 7i90_spi_svst8_8im2.bit 7i90_spi_svsttp6_6_7i39.bit 7i90_spi_svstua6_6_6_7i48.bit 7i90_spi_svua8_4.bit 7i90_spi_svua8_8.bit
Have you some recommended one? (for future programming through SPI )
I thinking about possibility of programming a SPI configuration bitfile through JTAG interface, because using of EPP interface with LPT port is little strange for me. I bought the 7I90HD because I do not want to revive any computer with LPT port.. Therefore, If I could use JTAG interface, as is described here for Xilinx: wiki.mlab.cz/doku.php?id=en:XVC_FT220X I will be happy.
Moderators: PCW, jmelson
Time to create page: 0.075 seconds
