Mesa 7i90 in SPI mode
9 years 11 months ago - 9 years 8 months ago #82429 by tinkerer
Replied by tinkerer on topic Mesa 7i90 in SPI mode
Last edit: 9 years 8 months ago by tinkerer.
9 years 11 months ago #82923 by sleepybishop
Replied by sleepybishop on topic Mesa 7i90 in SPI mode
hi joe, i tested your driver on a 6 hour job, seems to work really well. you should submit a pull request for it and hopefully itll get merged in to master.
how are your plans with the pine64 moving along?
9 years 11 months ago #82948 by jtheath
Replied by jtheath on topic Mesa 7i90 in SPI mode
Hello sleepybishop!
Thank you for running these changes. I am happy to hear your positive result. Could you tell me a bit about your system and job? What kind of machine is it and what speeds do you use? Are you running headless - no native display?
I have seen an occasional SPI Message timeout and am working on optimizing the standard spi-bcm2835.c code.
The Pine64 activity remains only a plan. I have the board running but need to apply the RT patches and enable the SPI device before rebuilding the kernel.
Once again - all the best! Joe
9 years 11 months ago #82971 by sleepybishop
my machine is an ultimaker clone ( www.thingiverse.com/thing:811271 ), i built two of them, im in the process of using them to build drone parts. the job i ran was the main frame. it was printed at 80mm/s with 150mm/s rapids.
im running them with arch linux arm instead of debian mostly as a personal preference of linux distributions and partly because it was easy to add the rt patch to their kernel package build. i run headless because though axis loads it does run a little sluggish and eats up a bunch of ram, so i run linuxcncrsh to send commands over the network, its a little backwards but i hope to make some improvements there in the future.
i have not seen spi message timeouts.
wrt to the pine64, ide love to experiment with these boards as well but seems like the kernels available are a bit behind, though support is slowly trickling into mainline, ( linux-sunxi.org/Linux_mainlining_effort )
thanks again!
9 years 7 months ago - 9 years 7 months ago #89329 by PKM
Replied by PKM on topic Mesa 7i90 in SPI mode
Hello,
I think I should ask here about jepler's Raspberry Pi adapter oshpark.com/shared_projects/bZNakuZs
I'd never ordered anything from oshpark before, so getting the boards was a nice experience.
Now I'm ready to solder, just need to make sure I do it correct.
Please check the pics
Warning: Spoiler!
Last edit: 9 years 7 months ago by PKM.
9 years 7 months ago - 9 years 7 months ago #89532 by PKM
Well I found well hidden "1" near 26pin connector and soldered the adapter correctly.
The board seems to work with Pi 2!
I flashed 7i90 with SPI firmware via EPP on a PC. But what if I want to flash another firmware via EPP? What I understood from the manual:
1. Set W3 down.
2. Power up the board with a backup EPP firmware
3. Set W3 up and flash primary firmware via EPP.
Is this correct?
I would prefer to install mesaflash to Raspberry Pi and flash via SPI, is it possible? Is github.com/micges/mesaflash the correct source?
Moderators: PCW, jmelson
Time to create page: 0.507 seconds
